Dealer over filled transmission fluid
Seanslane
Dealer replaced transmission.
Did a bang up job lol
Didn’t reconnect mounting bracket that holds the fuel lines up off of the transmission. When I am underneath there, I saw that the fuel line was rubbing on top of the transmission. Unbelievable. Also, there are two other harnesses underneath there that were not connected. But my question is.
They definitely overfilled the transmission. Hopefully someone can chime in and let me know how much they overfilled it. It is way above the mark. To me it seems like it’s four or 5 quarts above.
how you did you check it?
engine running, transmission hot, in park, on a level surface.?
if the above was not how it was done then your reading is innacurate.
S
Seanslane
I check it how the service manual says to check it when cold, since it was cold.
Running, level ground, hold break, go through gears, and so on.
But seriously? Even with a grossly inaccurate reading, would it be 1.75” above the hot mark?
Repeat the process except this time make sure it is warmed up at least 10 minutes of driving. The dipstick does not have a cold level mark only hot. Well I guess it does have a cold mark but that's only to make sure you have enough fluid to drive it.
S
Seanslane
If it is over filled just have them fix it
Thanks for the reply. I’ll did the same process and got the same reading after driving 30 miles.
I was just hoping someone would know approximately how many quarts over that is. That way I know, before I email them and let them know how they suck. What kind of service technician that works at a dealership, fills up a transmission 2” higher on a dipstick than the hot mark.
Probably 2 quarts is my best guess
Tupapi
