To good to be true? / Advice
dualie
Looking for some insight please.
I have been a long time lurker on this site. Appreciate the content!
I have been looking for a 2015-2019 Tahoe with max trailering for a little over a year now with a budget in mind.
Basically dialed in on clean title, max towing and low miles.
I have a deposit on a 2015 Tahoe 4WD LTZ under 40k miles for $35,000.
Its basically a 9 yr old Tahoe and 1 owner. Carfax looks clean and maintenance looks to be up to date. Car is tight and feels good.
Its being sold "AS IS" by a Ford dealer. We negotiated and settled on a price. I asked for a Chevy multipoint inspection since I am out of state and they agreed before I sign any thing and settle up.
My question to the group is two things:
A) If the inspection from the Chevy dealer comes back with problem codes & advisories- I should walk away right?
They told me that the negotiation is over now so whatever comes back is on me and is my issue, as it's AS-IS.
B) Can a pre-inspection from a Chevy dealer give a clean review? or is this to good to be true?
Or am I walking into a world of pain with a first year model year Tahoe as well.
The whole dealer process has been positive & they have been great thus far.
Thoughts?
Thank you.
GMT800 2005 Tahoe Z71
Navy Supporting Member
Welcome to your first post. IMO, when the vehicle is inspected by a shop picked by the seller and they also gave you the big warning, I cannot trust the inspection process. If I am looking for a tow rig, and not a pickup, I would look for a 2000 to 2006 3/4 ton Suburban or Yukon XL with a 6.0 and at least 3.73 gears or 4.10 gears and G80 diff. But that is me. I am not trained and do not know but I would stay away from an AFM engine.
D
dualie
Thank you! Appreciate the speedy replies.
More intel below.
Initially there was no warranty on the car. With AS IS on the window.
But now I have a power train warranty for 6m or 6k miles bc of the miscommunication.
The salesman was new and gave me the red carpet treatment, said a lot of things, but the finance guy squashed it. I said I’d walk if I don’t have something.. leaving the lot.
So my last request was to have Chevy look at it, which is happening today.
My choice. I’m 90 mins away and my mechanic is as well.
Chevy said they’d go through it with me.
My wife is skeptical & I don’t want to make a costly mistake.
Always said to myself I wouldn’t get emotional on a car purchase. Man it’s tough!!
I’ve read about AFM on the 5.3, leaking shark antenna, tranny 6spd issues, electrical.. Stability codes.
I have a funny feeling it’s too good to be true.
Milan
Thoughts?
Thank you.
Even if the dealer said that they're done negotiating, if the Chevy inspection turns up some serious issues, that might give you a chance to talk about the price again. Basically, if something big comes up that makes you rethink buying the Tahoe, you might be able to use that info to negotiate a better deal or ask for repairs. It’s always worth a shot, especially if these new findings could sway your decision to buy.
Darkstar72
I would request the Chevy dealer to make sure to drive it until it reaches operating temperature and to make sure there are zero transmission issues (no shudder or weird shifting once fully warmed up) and zero valve train noises whatsoever. Have the dealer look to see if the updated thermal bypass valve was installed for the transmission cooler to lower trans temps. If possible if they can just pop the level plug for a second to get some fluid out to check the condition. Then the usual - code scan for any current or history codes. If it is Magneride suspension make sure they inspect all shocks and struts for any signs of fluid leak since replacing all of those will run a minimum of $3K if going back with the factory units and sourcing out the parts yourself from online GM wholesalers.
If you do plan to tow with it a lot even if there are zero issues at time of inspection I would think most would recommend to replace the factory torque converter ASAP with a nice billet unit. Change the fluid out to the blue label Mobil 1 HP fluid and if it doesn't have the updated thermal bypass valve for the trans cooler get that installed immediately. Grab a Range AFM disabler to try extend the life of the lifters even though if they're going to fail it won't matter.
D
dualie
You were right on! THANK YOU! I got them to give more $$ off the sale price after the Chevy walkthrough.
D
dualie
Never ever be afraid to walk away. I would pay attention to your wife's spidey senses. You asked for opinions from people that have been there.
Here is the latest update as of this morning.
Chevy did a 172 point inspection for CPO'ing there cars. This was a paid engagement.
The tech ran his Code unit when truck came in and no code. The tech took the truck out to highway and no codes appeared live. So even if Ford cleared the codes upon the arrival of there used Tahoe, they should have showed up while the truck was driving now. Seems right?
Back at the dealer, they found & recommended:
A) front rotor and pads (pads were at 4mill) rotors could be resurfaced. 1 mil below bad on pads. Rears were fine at 6mill.
B) suggested an alignment. - pulled to the left on highway.
C) replace the Oil cooler lines as they were damp.
D) Recommended a trans flush now or soon before 45k miles.
The remaining trans, engine, exhaust, no signs of damage or accidents. Said all the fluids looked clean.
Otherwise, no additional codes or history codes.
The rear shocks were replaced in 2021, fronts looked fine - no leaks.
I legit talked to service advisor for 45 mins on this rig. He spend the time with me.
He said the engine bay was immaculate, inside the cabin was superb.
Suggested a thermal bypass valve and update the trans cooler, if I am going to tow a lot - like some said earlier in this post.
I spoke the dealer and we negotiated more off the price vs fixing it.
They will deliver it to my house 90mins away as well - that was always the deal.
I did decline there 3yr/ 36k Ford warranty ($2800) and found external 3rd party warranty from CarSheild that could work.
Sorry for the long note.
RoadTrip
FL & MN
Congratulations! Very exciting to get a new vehicle.
You can pull up the website to list all the recall for this unit and check the service records to make sure they have been done. And the nice part is those are freebies.
As far as the rest of the vehicle, yes, service those items and then do even more, like all of the driveline fluids, filters, hoses and belts. You don't want to be breaking down on the road so go 110% and you'll be glad.
D
dualie
Thank you all! Really appreciate the insight. Super excited to be in a new to me vehicle.
The dealer is going to register and delivery it to my doorstep this week.
Good or bad - I bought an aftermarket warranty through CarShield-Diamond plan. Covers a lot minus wear & tear with $200 deductible. Saw a couple forum members that have used this as well.
Will start all recommended changes:
Fresh fluid flushes, thermal bypass, trans converter - damn that torque converter is pricey!
Thanks everyone!
Dualie
If you don't mind us asking, what was the final price and how did you get there from the bottom dollar price they had said they would not go below?
the 18th letter
Northern New Jersey
And offer a 6mo/6k mile warranty. That’s good negotiating, from a firm as is price, to a discount with warranty. That’s how you do it.
vcode
Thanks everyone!
Dualie
Congrats! $35K seems a little steep as I got my CPO 2019 Yukon XL SLT w/45K miles for $39K. Seems like you talked them down though. How much do you plan to tow? I'm not sure I would tear the tranny apart to put a converter in if you are only towing 3500 lbs occasionally.
fozzi58
North Jersey
Sounds like you did well. The trans flush now, updated trans lines, and bypass valve are good steps. Consider throwing some money at an aftermarket torque converter. The factory torque converter are known to cause trans issues. A good one from a reputable manufacturer could go a long way in extending the life of the trans. It has for me
D
dualie
$33500. Final price
6m/6k pwr train warranty.
They register with new plates.
Delivery to my house.
We test drove and I said let’s go talk numbers.
I came in with KBB numbers which was 32,300 ish -Printed.
Showed him that and he said no. Ha!
Told him I never pay list. He came down $700 and we wrapped up. Then they hit me with a 600 doc fee. I called BS. (its by law i guess) we ended up splitting that and took it off the sales price.
We shook hands on 34k, warranty and delivery 90mins in another state.
The next day i called about plates, we spoke warranty - wanted that in the contract. They said, that's AS-IS. Sales guy said it had one, but in good faith, they gave me one - better than I thought tbh.
He called me back with that abovementioned warranty.
Had Chevy look at it and saw some other wear and tear (inspection) items. I asked for a reduction there without spoiling the deal. Thanks Alessandrolomb- That was all you!
That's how it went.
I feel like this was a fair deal. Would have loved a CPO and even a little newer - needed to stay on budget, but i have been looking for a while and most.. were over 80k miles for similar money, accident, no max towing and the private sale guy has lien on it. All deal breakers for me.
D
dualie
Thanks!
Thats nice deal. My budget was $35k, alot more players out there for $40k and up.
My car is up for sale now, so i should be net in the hole just under 10k which is perfect. Interest rates are obnoxious.
Thats a good question - I am towing 3 times a year about 7500#'s - flat roads a couple of miles each way.
I plan to trailer 2 hours away once a year. no mountain roads.
Thoughts around that?
D
dualie
Thanks! Will do on those items.
How do I go about finding a reputable torque converter? Gotta be a million players out there.
are torque converters specific to Model/ year of Tahoes. I am def not a car guy - sorry for the newb question.
petethepug
Michael
SoCal
Check your car shield warranty for the cost / deductible of not taking the truck to the selling dealer. You may need to add a zero deductible option.
Does it cover the MagRide as well as the air struts in back? Almost all GM parts have a lifetime warranty now so getting them replaced on warranty means free parts when the warranty is up.
The biggest expenses in the future are going be a/c, cooling system like radiator & h2o pump, trans, Navi - radio malfunctioning, steering rack, rear main & pan gaskets.
varminpoolteam
