Retrofit 2022+ Digital Instrument Cluster in 2021 Yukon Denali
thepiombino
Was wondering if it would be possible to retrofit the 2022+ digital instrument cluster cluster into a 2021 Yukon Denali. Can't seem to find much on the interwebs about it other than just theories that it may fit, but that some programming would be required. Anyone have any insight on this? Not a big deal, but would love to have it in my '21 if I can. Thanks!
WalleyeMikeIII
Sunny and Snowy Minnesota
You are definitely going to need to do more than a parts swap…because the 2021 uses the older GM software and the 2022 and up use the Google based stuff. There is software that runs it on the instrument panel cluster; and it has to be compatible w/ what you have onboard…net, I doubt you can just swap the part…there will be programming required. Suggest using the white stuff above.
bradac
I actually did it l, it requires setup though techline connect, I bought a ACDELCO TDS SPS subscription for my vin for 2 years, you can get an MDI from Amazon but the Bosch one also works. A dealer should be able to do it if you pay there fee.
bradac
Also to add I’m in love with it, trade in values are terrible right now so I can’t upgrade for a few more years but made me feel like I have a new suburban :)
StephenPT
St. Helens, OR
Awesome! Did you buy the MDI 2 for this job or already have one?
Excellans
Awesome!! Bradac, did you buy MDI2? Because I am looking at that, and the price was $1,475:(
StephenPT
St. Helens, OR
Clones are available - haven't dug into them too much. There's some videos of them on YouTube. When I get to the point that I really want/need one I will likely go the clone route.
wheelmanrob
This is a nice mod to the 2021's.
Do you think you can purchase a used cluster and still complete the swap with the programming tools you purchased? Or do you have to get the new $750 cluster listed above?
Excellans
Thank you for your kindly reply, Stephen.
I found this one way cheaper. I could go with that
StephenPT
St. Helens, OR
Awesome - they don't state that it is a clone. It has the GM logo on it, so maybe it's genuine? But it makes me wonder how they are able to sell it so cheap, whereas direct from GM it's over twice that price. If you end up getting it, let us know how it works!
Excellans
Excellans
Here is the 2021 Yukon / AT4 cluster update to 2022 digital cluster setup costs
ACDELCO two-year subscribing for SPS : $59 (CDN)
GM MDI 2: $475
GM 85577580/Digital Cluster: $386.90
Waiting the parts, wish me luck:)
sabisho
Hi does this work for a yukon denali too?
sabisho
GM MDI 2: $475
Did it work with the yukon ?
Excellans
It worked but needs to graphics update(Shows Z71 welcome screen:)) ) and reprogram for HUD(not working now). Maybe I need to visit dealer, because when I tried to follow instructions the Ecu could not connect the SPS2 and setup wont finish. Therefore I could not change graphs and HUD. Everything works except these two issue.
Shawpg
Hi, did you get the graphics and specifically the HUD fixed? I have a 21 Denali that I am interested in upgrading but its a no go if the HUD won't work.
GTPprix
Senior Member
Metro Detroit, MI
If you get the proper kit linked earlier in this thread it will work. Not sure where the idea came from but you cant just go buy your own cluster and throw it in there like he attempted. The Video posted in this thread is the setup portion of one of the kits listed below which comes preprogrammed with custom retrofit programming:
bradac
Hey guys I’m Brad the one who made the video, you need a legitimate GM MDI 2 or Bosch MDI (there basically the same tool) you can buy it directly from Bosch on Amazon, you also need a ACDelco subscription as mentioned. I personally borrowed mine from a friend who owns one but everything was done with official parts. White Automotive media is the only way I did it, and the only way I know of it working. As they pre programmed the module, all I did was run the setup command within SPS which I have a subscription for my car. It’s been working with issues to, and have had numerous warranty work done with no issues either from my dealer. If you have any questions let me know, I don’t work for any of these companies either, I’ve been on this forum for awhile just thought I share an update on my experience and answer any questions :)
Shawpg
Thank you Brad. Glad to hear your not having issues with your new guage cluster and no problems with warranty work. I'll work with White Atumotive. Also, I am not able to see the video you created, can you re-post it?
CrackerJack135
