fatmonk8
- Joined
- Mar 16, 2023
- Posts
- 261
- Reaction score
- 85
Hey all,
Back again with more issues it seems.
Noticed smoke coming from the tailpipe a while back amd though nothing of it. Since it was only a little and came out after a cold start or sitting for a couple hours I figured maybe condensation. Well I noticed it seemed to do it regardless of outside ambient temp, so hot or cold I would see the smoke. So that made me think it may not just be condensation.
Since i've had the car it had mild shakingwhen idling low, especially after it warms up. Figured it was just because it's a v8 with 100k miles on it. Went ahead and tried to clean the air flow sensor, throttle body, ect. But still had a rought idle. The idle is not so much that I was worried about ititit was just enough to annoy me.
So I decided recently to replace plugs and wires as generally maintenance and to hopefully solve the rought idle. I noticed the plugs had a little oil on the threads, not sure if that's a sign of oil leaking in or not.
I have also noticed the coolant in my reservoir is low, but I haven't had a chance to really mark it and watch it super close.
Granted I have had no codes thrown and the car seems to run fine, but the exhaust does smell sweet to me and the smoke looks white.
Any opinions? Would it misfire with no code? Could it have a very slow oil or coolant leak that could go unnoticed and cause the engine to idle rought at low rpm?
