2001 Suburban Heat/Ac
SpareParts
North Idaho
My Suburban has rear heat/ac. The front works fine but the rear however does not.
If i turn the rear on it will only blow cold air unless i turn it all the way to hot then it blows hot.
It will not self adjust like the front.
If i turn the rear on full auto it will only blow on high speed cold.
Any idea where to start looking for the possible problem?
It is relatively new to me so maybe i dont fully understand how it works.
SpareParts
SpareParts
North Idaho
Reading the forum i discovered a reset fix. Gonna give that a try Friday.
SpareParts
SpareParts
North Idaho
Many threads about it.
SpareParts
SpareParts
North Idaho
My HVAC was working fine when i first got the truck. I don't remember why but i had the battery unhooked for for a little bit one day a week or two ago.
I did not know about turning off everything HVAC related off, So it was set where it was when i unhooked the battery.
A few days ago i noticed the system was not working right. Defrost button works fine but the other 3 flash 3 times then go out also.
Hoping it's all just outta sink and a reset fixes it.
AdrienR
