2005 Silverado 4wd transmission codes 740, 758, & P2761
Summajet
I have an 05 Silverado crew cab 5.3L L460E transmission. I am getting codes, 740,758, & P2761.
I did a fluid/filter change two weeks ago and since that time I have been getting the codes. Fluid and filter were changed and replaced with ACDelco transmission fluid.
When I change the fluid in the filter it did not have a drain plug on the pan so I got out most of the fluid I could and the pan on the rear end of the transmission side did hang up against the transmission harness.
I have researched on the internet and came across several issues and what people posted was the fix.
1. Transmission harness
2. Ignition key
3. Pink wire running from the ignition fuse under the driver's side - to the transmission had a break in the pink wire circuit.
I cleared the codes two days ago and have driven it since with no issues. This morning when I started the truck up in the driveway to check engine light came on and it's the same as that codes as before which leads me to believe it's possible it's an ignition key issue?
I would greatly appreciate any helps or suggestions on trying to troubleshoot this issue.
Thanks
NickTransmissions
Sin City
The transmission bench
2. Ignition key
Thanks
My guess is you knocked something around taking the oan off or putting it back on - it's all to easy to do as those solenoids dont need much in the way of motivation to quit on you...
Drop the pan and stick a multimeter to all of your solenoids then check for voltage at vehicle wiring harness that connects to the transmisson. The ATSG manual will have the wiring diagrams. If you dont have the manual let me know and ill post screenshots of the relevant content here.
S
Summajet
I appreciate the reply. I did pull a wiring harness today just in case my current one is bad. clCan you post the images for reference.
Thanks
S
Summajet
Sorry, I pulled a used wiring harness from an 06 Silverado L460E at my local junk yard. I also was able to order a new harness made by Atp though Advance Auto just in case. At the junk yard I also saw a connecting harness that locks in place on the outer top of the transmission. It has two tabs that you push allowing the harness to separate. It provides me with feeling for the tabs as I am unable to see it while in the truck.
Thanks
NickTransmissions
Sin City
Thanks
Id buy a brand new harness but it's up to you as used ones have generally a poor track record...
Here's those images, sorry for the delay - it's been a busy day...
rockola1971
Indiana (formerly IL)
The solenoids just dont fail commonly. But the problem lies in the wiring harness within the tranny. It is constantly bathed in very hot tranny fluid and is cold/hot cycled. The wires and their insulation can get brittle. You may have caused a break in a wire and it just isnt worth the hassle to put a used harness in there. The wire (copper part) can be broken and the outer insulation can be fine. A simple ohmeter check can be made on the harness but id just yank it out and install a new one since yours is probably already baked to death from the tranny fluid heat. Check the old one on the bench to find the exact fault. While you are in there verify the filter is fully engaged into the valve body and make sure you have the correct filter installed. (Deep pan or shallow pan)
NickTransmissions
Sin City
I never ever reuse transmission wiring harnesses - they all go in the trash and new ones installed on reassbly. Hopefully, he got the junkard one for free or at most a few dollars...
S
Summajet
I appreciate the information. It is a deep pan and I installed the ac delco filter for deep pan. I am waiting till the new harness arrives before removing the pan. I agree only to use the new harness as any old harness will develop issues over time for bathing in hot fluid.
rockola1971
Absolutely. When a tranny is opened up for a rebuild or even just a valve body service or replacement then the harness should be replaced and I would never use a used one.
S
Summajet
I wanted to give an update. I am still having the issue.
If i use the key to start the truck it works flawless without any issues or codes. If i use the remote key fob, it sets the same transmission codes. I even tried using the remote start, then pushing the brake shutting the truck off, then inserting the key and starting up. It still sets the codes. I went by Best buy that had installed it 2 years ago to ask some questions. There is a sign by the install door stating hours TBD once an installer is hired. I have the proper voltage from the ignition switch to the harness at the pan. Proper voltage across the Ign 0 fuse.
I am going to try it with the key in the ignition and in the on position and use the remote. If it does not set the codes I am going to assume the remote bypass has failed or the ignition switch is bad.
S
Summajet
I was able to get an appointment scheduled with Best Buy today. I took it to the shop and the lead installer that manages that location and is a trainer for other locations, showed me what happened.
The pink wire under the dash was missing some of the insulation for the wire. The pink wire was touching the metal removable shield for the drivers protection. It had blew the 10am fuse on the remote start bypass module. When using the key no transmission codes. Using the remote produced codes. It was not getting poser to the transmission. He also fixed the other fuse that was twisted/inserted into the remote bypass. I was at the shop while he did the repair and he showed me where the fuses were located on the bypass module under the dash. It is fixed and am glad as i am now able to use it without issues.
Hope this will help someone else..
Hodmjstone
