TPMS question
spyderrider
Ok, question for y'all. I pulled the wheels and tires off my 04 Denali and put them on my 08 Denali. After doing some research, the Delco part numbers for the sensors are different BUT use the same freq 315mhz. In theory, I should be able to program the sensor to the 08, NO? Autel makes sensors and the same part numbers fit both applications. Has anyone done this swap with success? Thanks
strutaeng
Dallas, Texas
I would think so, yes. The Autel kit I bought had 8 sensors and are dual frequency (315/433). I programmed them on my 06 which are 315 MHz.
I don't know if it will work with AC Delco sensors, but I don't see why not. Do you already own the Autel programmer? There's a function to test the sensors.
S
spyderrider
Yes, I have the Autel handheld AND scan tool
albac
