SD Card Removed - and I did it! (Yikes)
tagexpcom
We're test driving a used 2021 Yukon Denali this week. All is going well, price OK, beautiful car, towing test was a success, everything works so we're likely to buy.
However, poking around I ran across the SD Card in the center console and popped it out, put it back in wondering what it was for. YIKES - the Nav system now says "SD Card Removed" and a little research indicates this was a bad mistake on my part as 1) they are vehicle specific and 2) corrupted when removed with car on?.
So what's the fix? Can I re-initialize somehow or does a special auto-shop need to work on this or ?
FYI We're set to buy after today's tow test, just need the independent mechanical review but no reason to think there's anything wrong. So this will be my problem and in any case I won't be 'hiding' anything with respect to the seller. Just need to know how to proceed :)
DougAMiller
Colorado
I think you may need to get a new Navigation SD card. I popped it out and put it back in shortly after getting my Escalade, and everything was turned off at the time. Nav would not work after that. I don't remember exactly what the message was, but the dealer had to get a new card for it to get it working again. Fortunately, it was covered under warranty, so I don't know what the cost was. I know these cards are designed to be single use and then they are locked to that vehicle.
tagexpcom
tagexpcom
Just looked up the cost of a map update SD card on GM's website. It looks like they are $150.
Can you share you're link? I found this for Seller Price: $262 but Retail: $452 at nearby GMC dealer - and I presume they have to install it?
- https://parts.gmparts.com/product/g...393,287903,287904,118734,318770,263723,205703
tagexpcom
tagexpcom
This is the website I was on, https://gmnavdisc.navigation.com/models/Catalog/Catalog_Cadillac_Escalade/en_US/GMNA/USD
If you click on 2021 you get the pricing. This is for the Escalade, but if you select GMC and Yukon using the menu at the upper right, the price is the same for a 2021 Yukon. It looks to me like this is the official GM navigation website.
Thank you - I see it. It looks like I can just order / install for $154.
RST Dana
OH
Should still be under the b2b warranty guys. GM should make this right off the dealer balks.
DougAMiller
Colorado
Yes, I believe so. There are instructions for installation there as well. I think it explains why mine was corrupted when I removed it. The instructions say to turn everything off and wait ten minutes before removing the card. I know everything was turned off when I removed mine, but I don't think it had been ten minutes. I've noticed that the system seems to stay on for a short while (even though the displays are off) after you turn off the vehicle, presumably for a quicker restart when you come back from pumping gas or any short pause. I'm guessing that the card can be corrupted if it is removed during that time.
petethepug
Michael
SoCal
Keep in mind that you don’t know the history of that SD card. It could have been a counterfeit or already corrupt. It’s best to get a factory replacement to avoid any tail chasing.
We had a seller on eBay selling SD cards for our 11-14 SuperNav that would corrupt the current SW in the unit and brick the unit. The only way to bring it back was to install the old, known SD card and it’s data/SW or a new, known working GM original.
Eplion1
I did something similar with my SD card couple months into ownership of my ‘21 Denali and it hosed the maps and Nav… dealer covered a replacement for me. Now we have informed all in the family not to remove it! Lol
tagexpcom
tagexpcom
They should put a WARNING sticker near it :) My replacement SD Card is set to arrive this week, will report back if I'm able to fix myself.
tagexpcom
tagexpcom
The SD Card arrived and all you have to do is
1) Turn vehicle off for at least 10 minutes
2) Put in the new SD Card
3) Turn vehicle on, hit Nav on the display and say Yes, Yes, Confirm.... and
wa la, it's working again. Many thanks to @DougAMiller for pointing me to the $165 solution :)
Came in this box (front, back) and install instructions on the back of the cover
RST Dana
OH
How many miles? Out of bumper to bumper warranty? Should have been covered if under 36k and 36 months
tagexpcom
tagexpcom
I just bought the vehicle used, no warranty, and popped the original SD Card out not knowing what it was for - which disables it/nav system and cannot be corrected w/original SD Card. Was glad to be able to correct my mistake.
RST Dana
OH
Used or not, it has a 3 year 36k bumper to bumper warranty. If it was within those limits, you might could have gotten a dealer to cover it at nc.
tagexpcom
tagexpcom
Ah - 2yrs but 50,000 miles.
BigdawgR6
I've poked around and still can't find this SD card. Where is it at in the center console? I have a '22 Denali.
WalleyeMikeIII
Sunny and Snowy Minnesota
You don't have the SD card, as from 2022 on, we got the integrated Google maps, and the associated need to be connected via data to keep maps up to date.
Look at it this way, the old vehicle required a $165 purchase annually to get updated maps, the new vehicle requires a $14.99/month data subscription which keeps the mpas updated and provides wifi data to any of your passengers, allows you to stream Pandora, Amazon Music, YouTube Music, and use any other number of apps...
The down side: we further sold our souls to google.
Hodmjstone
