Need advice on 20 inch or 22 inch for Yukon Denali 2023
mail2ifu
Hi Folks,
New to the forum here, lots of helpful responses so posting a question for some advice. I am trying to order 2023 Yukon Denali with Sunroof, the dealer says it will take 4 - 5 months but he has one coming that has above and 22" wheels + Onstar package. I read through internet people are torn between 20 & 22" wheels. Some say ride quality will suffer with one and others say handling will be worst. Does anyone have knowledge on this and can list pro\cons of one over the other from their experience, would appreciate it.
Regards,
Maverick
RST Dana
OH
Hi Folks,
Regards,
Maverick
I have had both on previous generations. No major difference as long as you have hood quality tires imo. 22 does look cooler on my RST I think.
WalleyeMikeIII
Sunny and Snowy Minnesota
I run the stock 22" Wheels in the summer w/ the stock Bridgestone tires (for now), and 20" w/ Bridgestone Blizzaks in the winter.
I don't really notice a ride quality difference; or if I do, it is so slight that it doesn't matter to me.
Handling: my belief is that with this high center of gravity, the treads will break loose long before any difference in sidewall height is noticable...its a bus, you don't drive it like a sports car. That said, handles great w/ both wheel sizes.
Furthermore, you can always find 20" take off's from almost any GMC or Chevy truck on craigslist or facebook marketplace at a big discount if you decide you want to go that route later. I'd take the bird in the hand...although you could consider waiting for the 2024?
M
mail2ifu
Thanks for the detailed response. I need to have this by 12/31 for tax purposes :D so can't really wait until 2024. Initially we were debating between Tahoe RST (like the looks of it) v/s SLT or Denali. Magentic ride v/s regular suspension. Unfortunately down here in Houston there are barely any dealers that have cars to test drive. Feels surreal buying 70-90K truck without really driving them between different options.
WalleyeMikeIII
Yes, I ordered my Denali having never driven one (did get to drive a used 21 suburban). Bet you could find a couple used ones to drive…or rent one for a day or two from Enterprise or Avis.
I will say, if you plan on towing, get the air suspension...helps a ton w/ sag.
morig
I got the 20s because we get out in the country fairly often and I wanted a little more meat to soak of gravel/dirt roads. The ride is super smooth but I will say the look of black 22s is appealing and might be an upgrade at some point. I’m also exploring the option of powder coating the 20s gloss black but trying to find some pictures of what that would look like before proceeding
Blueinterceptor
This was a tug of war type question for me up until the allocation was received. I built and rebuilt the car several times on the website and just couldn’t decide. One of the major sticking points was the number and type of tires available in the factory size of the 22” wheel vs the 20”. I was lucky and got a chance to drive each. And there wasn’t much of a difference in ride quality but the 22” have less body roll. I really like the appearance of the Texas edition wheels. When Michelin released the defender ltx in the 22” factory size, it sealed the deal. I will say this though. If Chevrolet had the Texas edition style wheel in a 20” size, I would have gone with that because of the number of tire choices available. I would have bought the Michelin all terrain tire.
Welcome to the Forum from NH.
Pics of the truck, please.
If you want to substantially increase the suspension/handling performance of your truck, install a pair of Hellwig sway bars.
GMCnewbee
Our Denali has the 22 inch wheels. Looks really good and the ride is great. Just keep the correct tire pressure. When delivered there was 45psi. I lowered it to the recommended 34psi.
tjs3922
Have 22"s on yukon and suburban. Ride is great my previous suburban had 20"s and never noticed a difference.
dcyy
Ordered my 22 Denali with 22's(SF2 wheel)-they were on constraint and it came with 20" Bridgestone's. Finally got my 22's with Michelin LTX tires-to me no difference in ride or handling between the two and it looks better Before/After
GatorRican
Hi Folks,
Regards,
Maverick
I have a Denali Ultimate with the 22s. Ride quality is quite good, although taller tires do have a slight impact on cornering. I prefer the look of the 22s, which fill the wheel well. However, they are more expensive.
ZKWBQD
Hi Folks,
Regards,
Maverick
OnStar is something I avoid. On the Tahoe I purchased I was forced to get it, but I never activated it and I have disconnected it. I would rather have 20 inch wheels for a smooth ride. Your tires are the first step in a smooth ride.
jimgeb
With 20" tires you have a little more protection from the potholes in the Northeast.
rico387
Brilliant! Get the 22” at order and buy a new set of take off 20”. It would be way cheaper than if you got 20” and decided you couldn’t live without the 22”.
Btw- I have 20” and I put the GM Perf/Brembo calipers on the front and had no clearance issue.
keithcruiser
keithcruiser
Gentlemen, I have driven Suburban/Yukons since 1981, owning 5 of them. The most recent is a 2018 Yukon Denali with 22” wheels. I found the ride a bit harsh compared to my previous Yukon with 20”. Both had Michelin Defenders as a direct comparison. I finally bit the bullet and bought a set of used 20” Denali wheels and new tires. The ride is improved on our occasionally pothole strewn roads. On a smooth highway both diameters perform equally well. The steering is marginally not as crisp as the 22” but who buys a full sized SUV for crisp steering? I am happier with the 20” wheels and certainly would not pay a premium for 22”. Like someone else said, the 20” tires are less expensive and probably more choices available.
Phlipnstik
