9 miles per gallon!!
h2100
White Lake, MI
Hello All!
My 2019 Tahoe LT (5.3L) is only getting 9-10 mpg while towing a 5,000 boat on the freeway at 65-75 mph. On my 2015 Tahoe I was able to get 14-15 mpg towing the same boat. Even back to my 2010, the mileage was never this bad.
Tow switch is engaged. The 'hoe has 75,000 miles on it.
Any ideas!?!?!
Miami-Dade
Moderator Supporting Member
Hello All!
Any ideas!?!?!
Moved you here. You posted in the 2021+section
Hello All!
Any ideas!?!?!
what was the gear ratio on the previous vehicles versus this one?
THarber
Did all of your previous trucks have a 5.3?
bsamole
Sparks, Nevada
Since you get decent fuel economy when you are not a towing. I was suspect the trailer is the culprit. Does the trailer have surge brakes if so are the adjusted properly?
houstontaylor
Remember that gasoline can have alcohol mixed with it. The more alcohol there is, a less the gas mileage is.
H
h2100
White Lake, MI
i'll check this. i can push it around the yard with help from the wife (with no boat/she's not that strong!)
Bigkevschopshop
Northside H-Town
Get your RPO codes from your glovebox and post the photo here, it really sounds like you have a 3.08 rear gear, if so that could be part of the issue. Do you use tow haul button and lock it in 4th or 5th gear on the trans?
tom3
When you're towing do you see the AFM dropping cylinders on easy cruise? Not sure how this works in tow mode.
albac
