03' Yukon Body Drop
89 chevy
Took some new pics today. It sits lower with the isolators out!
I will get a few others up soon!
---------- Post added at 10:40 PM ---------- Previous post was at 10:39 PM ----------
It sits even all the way around. It is currently sitting at 31.5in at all 4 corners. Wanting to go lower in the back.
---------- Post added at 10:45 PM ---------- Previous post was at 10:40 PM ----------
More:
Oklahoma
Looks good! I like the way the front bumper turned out. I think it makes the whole body look cleaner with the grill and bumper that close.
89 chevy
looks perfect what did you do again 89 chevy to get it so low ? suspension components ?
I did the DJM 3/5 drop. It includes LCA's, and 5in drop springs in the back. I removed the Isolators in the rear so its a 5.5in drop in the rear. Then we body dropped it. It lowered the truck 1.5in. My drop currently is a 5in the front, and 7 in the back. I am lowering the rear another half inch at least.
The wheels are 285/45/22 Boss 313's with Nitto 420S tires.
Thanks for the complements!
thehoe92
fo sho
The916
I really don't think isolators made you gain a half inch unless you have some crazy thick rubber on yours
and a 1.5" body drop?
you can only really get an inch, maybe a little more, before your bumper hits the grill and doesn't go any further.. same with the rear hatch
how much did just the LCA's lower you?
3"?
truck is looking good though
89 chevy
Well I am just going off the measurements. I will take a pic to prove it to you if thats what you need to believe me. There is no room at all between the hatch, in fact the hatch is resting on the bumper and it is rubbing the paint away on the hatch. You can't tell by the outside, you have to open the hatch so you can see it. And my rubber Isolators were .25in thick on top AND bottom so that's a half inch. The LCA's lowered it about 3.25in then I cranked the tortions down a lil more. If you don't believe me, I could care less.
89 chevy
Why would I lie about something like that? I know no one accused me of lying, but just putting it out there!
89 chevy
Yes, but the doors wouldn't shut right, and it would be a mess. If your going to body drop it at all, just do the whole thing.
thehoe92
fo sho
The916
I'm not saying you are lying I was just clarifying because a lot of the numbers seem way more than what they should
if you are at 31.5" you are at 31.5" I can't argue with that haha
but yeah if you had added you are rubbing paint off on your hatch I wouldn't have said anything about the body drop because I know anything more than an inch you will be REALLY close to not opening your hatch anymore
my bad if you thought I was calling you out!!
:Handshake:
clean454
the body drop just snugs everything up
i dont kno how ur rear hatch is scrubbn
did u cut the cone part out of the body mount?
to get that extra .25 or .5 or so?
Modded
That Guy
Just some quick input, isolators make a -0.3" difference MAX when removed.
They can measure .5", but you have to remember to think under atleast 2500lbs of weight they would not still be .5" thiick, they would compress pretty thin.
My proof is get a pair of regular pliers and squeeze them as thight as you can, the most pressure you would get is like150lbs and you can see how much thinner they get under that amount of pressure.
Not calling anyone out, but that 1/2" isolator fad running around here is getting old to my eyes. :Handshake:
89 chevy
Yes Clean, we trimmed the cone a quarter of a inch or so. Idk modded, thats just how much It lowered after removing them. Not trying to make anyone mad at all.
BaMaDuDe87
Bama
That looks good. You ever find anything out about what year S10 mounts are needed?
89 chevy
I didn't. I have done a lil research, but not finding anything. I think late 90's tho.
vsaravia
