Ok fellas got a big ass problem....t-case in 02 blew up
WhiteWhale2004
North Ridgeville, Ohio
So 4wd tcase blew up case is ****** up badly but I swapped an 04 yukon XL slt tcase into but the t-cases dont match......can someone please help identify them
rockola1971
Indiana (formerly IL)
They could be different models of the 246(E) because of the change around 2002/03 or one could be a NP246E and the other a NP241. There should be a round tag on the rear of the case. It will be completely opposite side of the front driveshaft output shaft. Near the fluid fill plug. The model number of the case will be on that round tag.
It will look like the following pic.
rockola1971
Look on your RPO code sticker It will have NR4, NP8 or ?? under the N codes. whats yours? What is the vehicle. I got that you have a 2002 something in the title. And the donor vehicle was a 04 Yukon XL SLT which likely has a NP246E.
What buttons do you have on the dash of your 2002 for the Tcase? 4hi,4lo,N,2WD or Auto4wd,4hi,4lo,N,2WD or ??????
rockola1971
You likely have a NP246 (Notice I didnt say NP246E) which is RPO NP8 on your RPO stricker in your glove box or center console storage area. In 03 GM went with the NP246E (E for enhanced) and made some changes.
The yukon XL 04 had either a NP246E (also called a RPO Code NP8 but not the same as a pre 2003 year NP246) or a BW4482 (AWD). Easiest way to rule that out is look at the 04 Tcase. Does it have a place for a shift motor to be installed or already have one on it? If it does then it is a NP246E. If it does not then it is a AWD Tcase. (Option NR4 RPO Code)
IIRC 98-02 is the interchange. 03 and up no dice.
i have seen parts listed like before but gm had there head up there butt during that changeover so when i had my 00 I learned pretty quickly to order for 01, the 03+ stuff looks pretty close but won't fit, I was told some of the 03+ transmissions can be swapped if the bell housing is swapped or something? just what i was told once
rockola1971
I learned the hard way completely opposite of your situation. I had a 99 GM Sierra SLT Z71 and it had the Vortec 5.7L 350. I had to order parts for a 99 K1500 or I would end up with the newer body style(at the time) parts like different suspension and even engine (LS Style) if I even thought about ordering for a 99 GMC Sierra Z71. 99 was a screwed up year for GMC because they made both body styles (generations) that year. Old model had 3 doors and the newer model had 4 doors.
That old truck and vortec is still going! Original engine. I bought truck with like 82K on it. That engine has over 300K on it now! Thats unbelievable for a vortec 350 chevy. The spiders have never even been replaced!
brice715
