What are your must-do things on new-to-you gmt900?
Malii Denali
Boston
if you take it to the dealer close to a grand, that cost is split between fluids and labor
these are "estimated" cost's from my dealer locally some of it I am not 100% sure, the $100 estimates may be low
trans: $250
coolant $199
brake flush $100
power steering $100
transfer case $100
front diff $100
rear diff $100
Thanks. I’ll give my local dealer a call in the morning.
AirJordan613
Northeast Ohio
When I was 1st in the market for a car that eventually led me to my Yukon, there was a 2009 Tahoe LTZ with the 6.2 @ 15x,000 miles for sale not too far (25 mins away) and I didn't know much about the variations. A week or so later when I realized I was going to need a new/replacement car the 2009 was gone.
They sell fast once someone realizes what it is.
mountie
I went to So. California, for 10 days.... last month......( '05 Yukon XL with 165,000 ) While I was gone, I had my TRUSTWORTHY mechanic do a service..... engine oil / filter, transmission fluid / filter, changed / flushed coolant & replaced my overflow bottle finally, drained/ filled front differential & transfer case. ( all looked good)..... and did an 'all-around' check while up on the lift.....
My invoice was just under $520. Wow..... not bad !! IMO
AirJordan613
Northeast Ohio
Heckuva deal
GMT800 2005 Tahoe Z71
Navy Supporting Member
I would have done all that for you for $500.
Monz11
Da Burg, Fl
Welcome to the Forum from NH.
Pics of the truck, please.
Be sure to change ALL cooling hoses, including the 2 plastic Tees near the fire wall on the passengers side, even if they look good.
I would suggest replacing the two plastic tees, with the aluminum ones, dangit the guy that's out of atlanta that machines parts, for the mirror gears, etc. those are definitely a lifesaver. If you're going as far as replacing all fluids and hose, you might as well pull engine, do cam, crank, bearings, rocker arms, etc. its so worth it, then hoses, fluids. Also, Atomic Fab & performance has by far the best engine mounts out there.
Geotrash
Dave
Richmond, VA
Gruven Parts. I took the Gruven tees *out* of my 2012. I couldn't get them to seal up and stay that way through the season changes. As soon as fall rolled around, I'd have leaks. Tightening the clamps would work for a while and then pretty soon...drip...drip...drip. Ended up just going back to the OEM plastic tees. Didn't have the same problem on my '07 so the Gruven teens are still there and doing fine. The problem is that they supply nice silicone hoses to mount them with, but worm drive clamps designed for *rubber* hose. I should have used spring clamps and I probably would have been fine, but oh well. Just wanted to let folks who might read this know that if they install the Gruven tees, use spring clamps.
donjetman
I installed the GruvenParts.com Ts and mirror gears 3+ yrs ago. PITA to install, but haven't had to touch'em since.
alpha_omega
Michigan
You might even go as far as to say that they would be better off using spring clamps on their hoses regardless if they are rubber or not. Worm drive work themselves loose over time, even if you tape or wrap silicone wrap them.
Did you use a heat gun on your silicone hoses to soften them up prior to install in order to get a better fit/tighter seal?
Geotrash
Dave
Richmond, VA
No, I didn’t. Might’ve helped. And I agree with your spring clamp suggestion.
wwiizz
