My Yukon Denali 2022 dead battery second time !
yyateem
Hi everyone,
Here is my story with my new yukon denaliy 2022 I bought the car last december 2022:
First day in the showroom to receive my car at the showroom it was not start ! Its completly shock to me and the jumb start the car and working fine but I refuse to take the car until full check again. Second the told the battey was dead and they replace the battery and they said its happening sometime. After a month i am not using the car everyday but i was turn on the car through the remote start for 10 min and auto turn off, usually i do this 2 time per week without moving the car after that again same probleme happing the car not start I jumb start the car but shows light engine is on. I took the car second day to delearshop and they check the car for 2 day and change the battery and said not use the remote start until we got a fix from GM. I was travel for a week and just now at this a moment i came back and the car not start ! Only one week I left the car and I jumb start the car its working but the engine light is on and the heade up display is not working !
So 2moro I will take my car again to the dealership and they will change i think for the third time the battey !
I dont have any idea to say to delearship but i am not happy with the car and i want full refund.
Regards,
Yusuf Yateem
B-train
I agree with your frustration. Something like a module or computer isn't going to sleep properly is my guess. Keep records and look up lemon laws for your state if you are that disappointed........which would be me as well
Hi everyone,
Greetings Yusuf,
You are doing more harm than good by remote starting the car for 10 minutes at a time. If you don't drive it much, put the battery on a tender to keep it charged up.
Multiple short trips and sitting for days at a time does not allow the battery to become recharged properly. These vehicle's computer systems wake up and runs tests and go back to sleep all the time.
Silverado4x4
Greetings Yusuf,
100% correct by him starting the vehicle with remote starting for 10min at a time the battery will not charge he is killing the battery everytime he starts and not driving it. Yusuf you need to buy a Battery maintainer for AGM battery's there is a difference between the old style chargers and one for the AGM battery. With these new vehicles computers, the battery is always working for the reasons said above.
Z15
Michigan ,USA
I agree with above, don't start it and let it run for 10 min. It could take up to 30 miles or 15 min of city driving to replace the juice used to start it.
I put one of these on my cousins Jeep Cherokee. Takes 5 min to hook up. She drives about 3,000 miles a year and it sits for weeks and goes dead. She's a snow bird, winters in FL and summers in Upper Michigan.
Battery Tender 3 AMP Car Battery Charger - Automotive Switchable 6/12V, Fully Automatic Battery Charger and Maintainer for Cars, SUVs, and Trucks - 6V/12V, 3 AMP Charger - 022-0202-COS
steiny93
A new yukon should last 30 days if it's left alone (locked, no keys in it). if you start it a few times a week for 10min a crack you'll drain the battery. If you are in and out of the vehicle you will also drain the battery.
For you,
Have the battery load tested and don't remote start the vehicle if you aren't going to use it.
WalleyeMikeIII
Sunny and Snowy Minnesota
Note, battery in the 21+ is an AGM, and you should get a tender or charger which can handle the slightly different charging profile and float voltage of an AGM battery to maximize it's life.
Stbentoak
The de facto standard charger for most OEMs is the CTEK brand. I’ve had them for years, they work impeccably on AGM’s.
I’ll leave them on for months at a time. Battery is always in perfect and peak condition.
Y
yyateem
So, any updates?
Still my car in the dealer for 2 weeks, 2moro it start at 3rd week, they call me to bring my second key and they found there is something at rear climate control its give signal to battery after the car is turn off ! + if they key inside the car still there is some power goes to battery which is kill the battery.
our dealer open a ticket with GM and still they not finish.
Hope to get good newa next week.
Y
yyateem
For you,
When 2nd time my battery dead i didn't use the remote start, but they found something else drain my battery while the car is turn off.
Its something in my rear climate control give a signal to battery + they told me to bring my 2nd key because there is some power goes on while the key inside.
I am still waiting for the 3rd week now and my car at the dealer.
B-train
@steiny93 I agree. I will leave my yukons for many days, sometimes weeks without running them and they always start. Even with chargers plugged into the port that doesn't sleep (2008)
@yyateem , glad ro hear they found it. I speculated that a module wasn't going to sleep. Now they just have to figure out why. My guess is an internal contact on the board has a bad solder joint or fried relay.
Dh1280
