Corsa catback 6.2 Yukon XL AT4
TrueAt1stLight
Minneapolis
Sounds awesome. Mine arrives today...pumped. Some quality time under a 7000lbs truck on jackstands.
What's interesting, if you look at the GM Performance Cat-Back #84888292, looks VERY similar to a rebranded Corsa. Spidey sense says it is.
Good luck with your install! I’m 99% sure the GM performance exhaust is a rebranded Borla, but certainly could be mistaken.
When the dealer tech installed my Corsa, he said he had to remove the lower control arm temporarily and drop the spare tire. @Fast_AT4 can probably confirm if he needed to.
MrScrewzloose
SW Florida
Yep, I believe the Borla one is #19433763, the parts description even mentions Borla. I was referring to the other 6.2L GM exhaust, #84888292.
cn27
I have the corsa on my denali as well. Love it but it could be a bit louder.
Fast_AT4
Fast_AT4
RWM +1
SW Florida
Yes needed. But can do it without lifting or any other tasks.
Edit: Thanks for reminding me...need to put my spare back on.
MrScrewzloose
SW Florida
Well... I did the install this past Friday, no stands or ramps. It was tight on the side, especially trying to lift the muffler drum section into place, it slipped once, busted my lower lip... install battle wound. Were you able to torque to spec the clamp on the connection point above the rear suspension cross member? I wasn't able to get an angle torque it down so hand cranked down tight.
Did about 40 miles of driving, it's still burning off the oil residue (burning smell is strong) so I'm a bit paranoid about leaks.
I also noticed the rear tips do not align dead center in the rear facia cutouts, each side sits closer to the outside of the cutoff with a larger gap on the inside of each tip section. I'm guessing others are seeing this?
Sounds amazing... very pleased. Still waiting on the wheels to come in but in the meantime getting alot of looks doublechecking the sound coming from a vanilla looking soccer mom'ish Suburban.
AliBaba
Seattle, WA
I’m confused about the exhaust and hoping someone can iron this out for me. I have not changed the exhaust on a vehicle in over 15 years so a little out of the game.
Does Corsa make their own exhaust or do they resell?
If i look on Corsa’s website they are much cheaper than buying from GM? Same kit?
If the Corsa kit is just Borla why are they cheaper?
GM site $2495
Borla Site $2036
Corsa Site $1669.
Fast_AT4
Fast_AT4
RWM +1
SW Florida
GM site $2495
Borla Site $2036
Corsa Site $1669.
I think (and I might be wrong):
GM / Borla same exhaust
Corsa is different than Borla
H1Chester
GM site $2495
Borla Site $2036
Corsa Site $1669.
It is my understanding that Corsa exhausts are also made to order, meaning they don't have exhaust kits just sitting on the shelf collecting dust until they sell. When you place your order then they make the exhaust.
Fast_AT4
Fast_AT4
RWM +1
SW Florida
Yes, I found this out after ordering as well.
WICKEDOWESIX
Just the sway bar ends and spare tire need to be removed when installing the Corsa Sport cat back syste. It's fairly easy, took less that 45 min to remove the old and install the new one.
I also added the Corsa resonators a week after install to give it a deeper tone (which I like a lot better).
H1Chester
I have a 5.3 and don't have the quad exhaust. Not sure if I want to do the quad exhaust conversion. I think the dual tip dump out the rear passenger wheel is too low to the ground. I'm considering just getting a Corsa Pro Series muffler and Corsa tip and getting a turn down exhaust dump setup. Muffler and tip would be $500-ish plus the labor...
AliBaba
Seattle, WA
Not sure where everyone lives but I’m in the greater Seattle area. Ordered the 6.2L Corsa setup for my 2023 XL AT4 and will be looking to sell my factory exhaust if someone wants to do the OEM conversion from side to quad rear.
66 Galaxie
Info on the Corsa resonators? Will be installing mine soon and may want to go with a deeper tone.
Fast_AT4
Fast_AT4
RWM +1
SW Florida
Is it also louder or quitter but deeper? PN please.
WICKEDOWESIX
It is quieter. The resonators are 2-3 dB quieter.
WICKEDOWESIX
66 Galaxie
If you have chance to share a video for us so we can hear it that would be great.
Thx!
BadDaddy2003
