p0454 p0455
msarles1
anyone ever tackle these 2 codes? if cleared will come back within 20 miles. any suggestions? 2009 denali 6.2
GMT800 2005 Tahoe Z71
Navy Supporting Member
P0454 is the EVAP system pressure sensor problems.
P0455 is the EVAP system :
  • Missing or loose fuel cap
  • Incorrect fuel filler cap used
  • Fuel filler cap remains open or fails to close
  • Foreign matter caught in fuel filler cap
  • Leaking EVAP Canister
  • Leaking EVAP System Hose
  • Leaking Fuel Tank
  • Faulty Fuel Tank Pressure Sensor
The common denominator is the pressure sensor. You can lead with that and cross your fingers. I did my entire system when I did mine but some do have luck here, going piece by piece.
Welcome to the Forum from NH.
Pics of the truck, please.
I cannot personally help you with your question; however, other members on this Forum that are much more knowledgeable than me will chime in.
By pure definition:
P0454 is a diagnostic trouble code (DTC) for "Evaporative Emission Control System Pressure Sensor Intermittent". This can happen for multiple reasons and a mechanic needs to diagnose the specific cause for this code to be triggered in your situation.
The P0455 code indicates that there is a large leak in the EVAP system, but this is somewhat misleading. What the code really indicates is that the EVAP system has a gross leak.
Or it could mean that the fuel tank pressure sensor is giving faulty readings. Need a good diagnosis to pinpoint the issue. A purge and seal procedure would go a long way...
jk6062
