need help cruse control
kickitandholdit
GA
my cruise control does not work.. all the light on the tahoe work. the cruise control light wont come on an it wont work UNLESS IM HOOKED TO A TRAILER. i thought this was weird but i unhooked the trailer lights and cruise quit working and when i hooked the trailer lights back up cruise worked again. i need help on this one lol. thanks in advance.
Narco
Atlanta
cmon kickit...you know better than that. how long have you been here now? =)
05Yukon
Houston
You have a short happening and the LED tails might have something to do with it. You probably need to add some resistors to the led tails.
Rivieraracing
If you have your stock taillights still, swap them out with the LED and see if that solves your problem! Easy way to see if the tails are the problem or not!!
BillBlatt18
Latham, NY
I am getting LED tails this week, and don't want this happening. What ones do you have?
Eagle
Thansk for all the help -STAFF!
EL PASO, TX
They are the problem... by connecting a trailer he's already added resistance which makes it work again.
Just need to add some resistive loads to the brake lights.
kickitandholdit
kickitandholdit
GA
i got normal aftermarket tails but led bulbs because they dont produce heat so they wont melt the tail lights cause there is plastic close to the bulb
---------- Post added at 12:47 AM ---------- Previous post was at 12:43 AM ----------
resistive loads? not familiar with the terminology
BlizzardX23
Sacramento, California
You just need to purchase the real LED tails...they have resistors built in....it will bring your CC back and look better :)
05nali...this situation wont happen to you...your getting tails with resistors built in already
CKendrick
