Magnaflow catback help
07PPVTahoe
PA
I bought the magnaflow catback system number 16672. Can anyone help point me to the right bolts to replace if I have to, and does it have a gasket? Autozone or rockauto is just showing me exhaust manifold bolts and I'm having trouble looking while at work. I'd like to install after as it just arrived. System I got
It's got everything you need unless something is missing.
Oh? I called magnaflow and they said it didn't come with bolts or a gasket
That's odd as their own website shows them! Ok, the instructions say to use the OE bolts to connect the exhaust system to the y-pipe. Is this what you mean?
If so, I am not 100% sure as my exhaust uses a clamp in that position. My trucks are newer and show that they are M10 x 1.5 and could be 11547135 and if a stud it would be 11589264 and the nut for both is 15032594. Double check in case I made a mistake, my wife tells me I'm not perfect!
07PPVTahoe
07PPVTahoe
PA
These are what I'm talking about
07PPVTahoe
07PPVTahoe
PA
Thanks guys, I ended up just cutting the bolts, they snapped immediately even tho I've soaked with PB. Got grade 8 bolts nuts and lock washers and installed the catback no issues otherwise. At the dyno tune right now. Thanks!!
07PPVTahoe
07PPVTahoe
PA
also interested in dyno numbers
Hey guys sorry I never saw this. I put down 285 whp and 312 wtq with very few mods. Unfortunately it spun a bearing 2 months after, I got a new camaro and havent had time to do the 6.2 swap. And am moving soon. So unfortunately Im selling it. Id really like someone from the group to get it and continue the build
Eickybobby5050
