Which sub to pick for this amp??
nastety92
Rockland, MA
I have a Alpine MRD-F752 5-Channel Amp that I plan on using in my 97 2dr Yukon.
Can anyone recommend a single 10" or 12" sub to use with this amp? I'm going to run only front speakers and a sub. 5.25 or 6.5" and tweets in the front.
Here are all of the spec's, let me know if you need any more information.
Alpine MRD-F752 V12 Class T Amplifier
RMS Continuous Power (Watt) (at 12.0V 20-20kHz /* 20-200Hz 0.3% THD): 4 Ohm Stereo (0.08% THD) 75W x 4 + 250W*; 2 Ohm Stereo (0.3% THD) 100W x 4 + 250W*; Bridged 4 Ohm (0.3% THD) 200W x 2 + 250W*
I'm looking for the sub box to be roughly 1-1.5 cubic feet total. I'd like to keep the box as small as possible so I can still have a rear cargo area. I was running a older BA Pro 12" sub and it wasn't working right in the past. I believe that was a 2ohm sub though.
Thank you for the help,
Nick
blueflamed03
Oklahoma
Kicker CVX or Solobaric Classic
CVX= 1.25 sealed 12"
Solo Classic = .88 sealed, 12"
N
nastety92
Rockland, MA
Thanks for the reply. I really appreciate it. So the Kicker Classic is a higher end sub compared to the Classic?
I'm sorry I'm not up to date on the newer car audio equiptment.
Do you think this amp has enough power for the CVX? What would you recommend a 12" CVX or 10" Classic?
Thanks again,
Nick
blueflamed03
Oklahoma
if you need small box, Solo Classic, if you have around 1.25 cu.ft, CVX 12" over classic 10".
N
nastety92
Rockland, MA
Thanks for the reply, I really appreciate the help. I'm going to measure the area and see what type of space I have then I can decide on the sub from there.
Nick
brice715
