2011 Chevy Tahoe PPV
Jerryrich0806
Whats up I have a 2011 chevy tahoe ppv. Rides good only problem I'm having is there's a vibration at low speeds. Can someone help me out with this? Thanks.
Welcome to the Forum from NH.
Pics of the truck, please.
You are going to have to give us much more detail about your issue, in order or us to assist you.
What is low speed?
Is the vibration audible, or do you just feel it?
Where on the truck does the vibration appear to be coming from?
Does the vibration change when you apply the brakes?
Does the vibration change when you turn the steering wheel?
Miami-Dade
Moderator Supporting Member
Welcome from Miami Beach!
J
Jerryrich0806
What is low speed?
Speeds around 15 to 20. The vibration comes and goes around that speed. And you can hear more than you can feel it. Sounds like it's coming from the rear.
J
Jerryrich0806
CrashTestDummy
Pearland, Texas
At low speeds and constant throttle setting, DOD is a lot more pronounced, which is a possibility. It can become more pronounced if the mot mount(s) need replacing. Failed motor mounts, especially the driver’s side one, are a common issue with these trucks.
Verify you’re not just experiencing DOD, at low speeds.
Sparksalot
Bastrop County, Texas
I noticed the same thing at that speed, and it definitely was the dod/afm engaging. I started using manual shift mode pretty quickly after that to inhibit the mode.
I bought a Range device soon after. Then learned about the ability to switch it off with a tune.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
What is the speed of the vibration? Wheel speed? Engine or drivetrain speed? You try tow/haul mode to see if it goes away?
J
Jerryrich0806
Around 15 to 20 miles an hour may just end up taking it to the dealership and no haven't tried tow/haul mode.
J
Jerryrich0806
So the vibration goes away I need more information on this dod/afm
J
Jerryrich0806
I had a motor mount replaced (driver side)
J
Jerryrich0806
I changed driver side motor mount
Jimgeorge
Florida
What is DOD?
Jimgeorge
Florida
'Displacement on Demand'. Under light engine loads and under certain speeds, the engine goes into 4-cylinder mode. It can sometimes come across as a miss or vibration, depending on your sensitivity.
I get a vibration at 40 mph. It feels like a tire is out of balance bad.
1BADI5
DMV
Yeah I went with the solid mounts with poly bushings from Atomic Fab.
replacing those stupid OEM motor mounts every few years would be annoying
Fubar0715
Scott
Southern New Hampshire
I have been reading this and it just occurred to me-at low speed, I noticed a vibration too and thought it was the trans being fussy in the wrong gear going slow. In hindsight, since getting new mounts put in, I do not hear/feel that anymore....I swear, this site is sometimes like church cuz now I see the light!!!!!!!!! :)
J
Jerryrich0806
I'm getting a grinding/vibration in the rear. What causes this. It comes and goes.
BadDaddy2003
