noob diesel questions
Steebu
Hiya, hopeful Duramax owner here with some extreme noob questions, so please bear with me. I did do a good bit of research but wanted to get this forum's input since we'll have some good tribal knowledge here regarding this specific engine.
1. Does "any" diesel work in the D-max? Biodiesel, #1, #2, #4, synthetic? Can you switch based on availability with no issues?
2. Do you need to add a fuel additive?
3. Any 'ol DEF work, like the stuff on Amazon? Better to keep it consistent or can you switch brands as needed? Any brands to avoid?
4. Due to garage constraints, planning on reverse-parking in the garage but that puts the exhaust just under a foot away from our gas water heater. When idling/warming up are there gigantic clouds of black soot shooting out the exhaust pipes (exaggerating, of course - but hope not)? Is this going to potentially damage the water heater? I don't think there's any kind of "intake" on the water heater; the flue and piping are all up top anyway but wanted to doublecheck.
5. About city driving: majority will be 15-minute drives to-and-from work, with several days of inactivity in between. We won't be marshalling cars around in the driveway so it's not like there will be 30-seconds of activity and then none for a week, but the majority of the trips will be short. Summer will have long camping trips and winter will have long drives to the mountain.
6. About winter driving: will parking for a few days straight at the ski resort when it's below freezing below cause any issues? Any tips/thoughts/aftermarket mods needed? Again, we're talking about a few days to the mountains - we don't live in Montana under 4' snow (although that sounds awesome).
Thanks much!
Pro299
There will be various advice. All free. Here's mine:
1. Use only Diesel #2. It gets blended for the season wherever you buy it. #1 is for extreme cold (think Prudhoe Bay). As for Bio, I think the limit is B10 for the 3.0. It's in the manual. It's not available in my area and I don't look for it when travelling.
2. No. (And yes, there are many who use additives. I only add them to my 6.6L since the fuel standard has changed since it was built.)
3. There is a standard for DEF (ISO 22241), and it should be labeled as meeting all US standards. Don't try to cheap out and it will be fine.
4. It won't hurt to start your vehicle close to a gas heater, but no way I'd let it sit idling in a garage to warm up--heater or no heater. There's no smoke from a modern diesel, and usually no smell unless you happen to hit a Regen cycle just right.
5. I often drive 15 minutes or so and have had no problems. There are occasional longer trips, so I don't even think about it. I just drive it like any other vehicle. This is a modern engine. If there were any expectation that serious damage would result from certain kinds of usage you can bet GM would have found a way to sound a warning and throw a code.
6. No personal experience since we only get mild winters here. A few nights in the single digits is about as bad as it gets. I don't even use the block heater, although I'm glad it's there, just in case I ever find myself having to go further north in winter than I ever want to again. Our skiing days are in the past, so we only go to the northern tier from May to September.
Snowbound
Jim
Chicagoland (Lockport)
I believe @Pro299 covered it pretty well. Only thing I would add is biodiesel has better lubricating properties than the other ultra low sulfur fuels.
As for additives it’s not a bad idea to use some anti gel in cold temps, what they add to the fuel is inconsistent. I add some cleaner and cetane booster every other tank but keeping filters clean are the most important.
Stbentoak
Also on #3.. just use Wal mart Super Tech DEF. Cheap, always fresh, and available practically anywhere.
Don't waste your money on fuel additives, they just drive your cost per mile up. Maybe a little Power Service if its super cold in the winter (like 0F or below..)
But by and large, additives are just not needed...
Some folks wake up to dead or low batteries after many short trips. The car is not on long enough, or going fast enough to get the battery fully recharged. I can't say that your commute will do that, just keep it in the back of your mind and maybe check the voltage at the end of a week. I keep a battery tender on mine when our trips get short and few.
CTown Duramax
PS - I don't think any of the concerns you raise should stop you from getting this great engine. I drive our Duramax in very heavy traffic most of the time, no problems. If you go into regen in stop and go traffic, just keep driving until regen stops after you've gotten out of stop and go traffic.
Rangerdeepv
If I am in traffic or stop and go when the regen light comes on I will keep driving until it goes out.
Pro299
what?
There's a REGEN indicator?
Nope. That's one of the reasons i don't pay any attention to it. If it were really critical, GM would at least provide some form of signal so you'd know when it's entered the cycle. I can usually tell by the sound of the exhaust but that's the only indication you get.
Jtpmedic
I had a Colorado ZR2 Diesel, it didn't have one either.
I heard this and was getting all excited.
Just more roller coaster of emotions...
LOL
S
Steebu
That's great to hear. But at this point, the only thing that's stopping me from getting that engine are the stupid supply chain issues ... o_O
steiny93
I'd add in the following (we have a pair of the baby diesels, one Ram one GMC and we live where it gets cold, it was -28F ambient this morning).
Don't use additives, 99% of folks will cause more harm then good; buy from high volume places and use winter fuel in the winter.
Winter starts; aside from the need to use winter fuel the starting is the same as any other modern gas vehicle. If it's really cold and it's outside plug it in, just follow the instructions. Below freezing is fine, -30F it'll want to be plugged in.
CTown Duramax
Well, if I notice it's in regen, I keep driving. I think the manual supplement says to do this.
CTown Duramax
Just to add another perspective to this, we have a garage that stays just above freezing when it gets toward 0 deg F and have had no problems using regular year round fuel.
BadDaddy2003
