2021/2022 Tahoe/Yukon Third row seats removal?
genestoy
Arizona
Well, here we go again. Spent some time yesterday at a local dealership that actually has a 2022 Yukon SLT available for sale on the lot (wrong color for me, onyx black) and as usual GM once again has not made the cargo area completely flat when the third row seats are folded down so I will need to remove the third row seats and cargo storage box and replace with a piece of carpet covered plywood like I have in my 2015 Yukon (I was one of the very first to do this back in 2015 and posted the instructions here on the forum). So, has anyone here done that yet on their 2021/2022 Tahoe or Yukon? Any pointers? Pics with the seats removed? My ordered Yukon is not here yet or I would already be doing this.
Thanks
Thanks
Looks pretty flat to me, why do you need it perfectly flat?
G
genestoy
Arizona
I carry some pretty heavy items that go behind the 2nd row bench seat(s). They need to slide out to the back and vice versa. The problem is sliding them back in over the "hump". It may look flat but the 3rd seats have about a 3" rise above the cargo storage box which is not flat.
Ok, I see it now, the little panels at the bottom of the seats appear to be the culprits. First saw those on our 2006 Pontiac Montana. We were always snagging them with smaller items but was ok with plywood and lumber.
SparkyLisle
Thanks
I removed the 3rd row in my 2019 tahoe. Remove the remaining bolts, disconnect the quick connection wires, and take it out. Bought a mat from weather tech, and it looks stock.
Reddevil96
Chandler, AZ
probably look into the parts for a PPV suburban. If you can find a VIN to do so. If remember right the PPV tahoe's do not have a third row or cargo box, just a rubber mat.
CBG1
Thanks
Hi. I have been following your seat removal discussion for years. I followed what you did for your last vehicle and it worked well. Now I am contemplating a 2023 and am concerned if I remove the second and 3 rd row there will be a “ well” of space which will require a platform. Did you ever come up with a solution to yours?
G
genestoy
Arizona
Yes, I left everything in place and cut a 1/2" piece of plywood covered with black thin carpet and added a couple pieces of 1 x 6 underneath near the rear to level it. Now it actually has as much room as the 2015 did and looks great, only takes a couple of minutes to remove if I ever need the rear seats.
CBG1
Genestoy can you please post a picture of your seat removal? I am trying to decide how to go about this on a new purchase. Currently I took all my seats out on my 2011 Yukon xl Denali and floor is flat in two sections, I use plywood. I am concerned about the well that will be left in the 2021-2025 model. Can you please help me?
Thanks
CBG1
Also does taking out the seats cause any codes to be thrown because of electronics?
StephenPT
St. Helens, OR
There might be codes, but they won't show up as a check engine light. Only when you connect a scan tool and do a full scan of all the modules will you get a warning.
I would be mindful that if you disconnect the wiring from the 3rd row power fold motors, you might cause a battery draw. GM published this article which talks about a battery draw issue because the BCM doesn't fully go to sleep if the 3rd row power fold connector is not fully seated at the switch.
G
genestoy
Arizona
As I said, I never removed anything. The third row seats are folded flat the way they come from the factory and I cut a piece of plywood to lay on top of the third row seats and the rear floor. It is about 4' square. To make the plywood perfectly flat I added a piece of 1x6 (screwed to the plywood) at the rear between the plywood and the rear floor and then covered the whole piece with thin black carpet.
Big Jim
