How is the subwoofer in the stock 21+ Bose system?
Kpwweb
Yes. Bass is better in the 21 vs what it seemed like in my 16. I also put in infinity front door speakers, Kenwood dash speakers and Rockford rear door speakers.
But I wish someone would come out with an add-on sub like the 15-20 had.
The aftermarket speakers help a ton; just wish for a little more.
R32driver
I think it sounds fine. Definitely not going to shake your rearview mirror or anything but seems adequate. The older I get this kind of thing has really lost it's cool factor for me though
BrokerThis
'22 Denali Dmax
Detroit
@Kpwweb did you put those 3 different aftermarket brands into your 16 or 21 ?
Also, just more of a curiosity question.... why not stick with one brand, how did you end up with 3 different ones?
Kpwweb
Both.
infinity had the two ohm 6x9 speakers for the front door; Kenwood had better dash speakers; and Rockford had a larger 6-3/4” cone for the rear door 6-1/2” opening. Would have liked all the same, but no one manufacturer had all the check boxes.
nosidamde
I have the bass in the EQ turned all the way up to get a sufficient amount from the system.
This has never changed in my experience for any GM Bose system over the last 20 years.
I've always joked, "All highs, no lows. Bose".
Tahoe210SA
Both.
Can you tell me which model numbers you got for each?
R32driver
Seems like Bose has always been overpriced, overhyped and really underwhelms. With so many better offerings out there I wonder what it is that keeps GM using bose?
91RS
GA
All about the money.
Baja_Bob
Michigan
Is there a subwoofer in the '21 tahoe/yukon? Could've fooled me.
Fast_AT4
RWM +1
SW Florida
In my Acura RSX as well as my Ford F250 SD, both had Bose....the OEM system never stayed long in both vehicles due to lacking quality. But even in both of my BMW M5's (HK and B&O) those were also lacking. In the RSX, the entire system was pulled...in the F250, I kept the Bose amp strictly for the purpose of a remote wire for my LCi/Amps. When the time comes, would a similar process happen on the AT4...just tapping off the stock amp for remote to add some bass? Anyone happen to have a pinout/writeup on adding some subs/amp?
Yukon_
Missouri
Yeah, Bose never really wowed me. To a 2016 Tahoe I added a sub amp with sub box behind 3rd row at the cost of loosing storage space. But that did help the factory Bose system out a bit.
JasonW4141
