...Reminds me of the slip/ non slip additive in the G80’s. So many opinions, so few facts.
Ah, yes. The ol' G80 additive conundrum.
I think the main confusion was from people trying to associate G80 with a particular type of LSD. "G80" is just a GM RPO code for "Axle Positraction, Limited Slip". It has no bearing on the specific type of LSD that is in the housing. G80 on the RPO sticker just meant it had some sort of LSD.
G80 in an S-series meant it had the Gov-Lock. G80 in a fourth gen F-body meant it had the Zexel Torsen. One used clutches and a friction modifier, the other used plain gear oil. They were mechanically interchangeable.
It finally stopped raining Saturday so I washed The Beast. Then Sunday morning I woke up to a light dusting of snow. It was grocery day so now it’s dirty again. Kinjo was like “ snow? this ain’t no da*n snow !” He looked so disappointed on his morning walk.
watchesandputters
Just wrapped up replacing the only brake line the previous owner didn't replace (rear one that runs from abs block to the rear splitter hose) with a stainless line. For anyone who happens upon this I have two pieces of advice:
1) DO NOT go with stainless lines, they cost me a ton of time and frustration until I found an obscure piece of advice on a random corvette forum thread. Even though it made all the difference I'd still go with a flexhose or nickel/copper line if I had to do it again.
2) If you decide to ignore my first piece of advice (don't) it is pretty easy to fish the pre-bent lines from the rear wheel well forward over the frame. Once you get it started above the frame from said wheel well try and walk it down over the frame while you're under the frame as much as you can.
What was the advice you found?
watchesandputters
To put never seize on the back of the flare and on the inside of the corresponding flare nut. I tried no less than 30 times (probably more) to get where the line meets the rear hose seated perfectly, the nut hand threaded quite a ways down, and followed up with a wrench just watch it weep and weep and weep. Did the tighten it down, back it off, and go 1/6 turn farther a number of times just to get the same result (by this point I was putting an uncomfortable amount of force on the nut).
Once I added the never seize it's still the same process and still required way more force than you'd imagine to get the stainless flare to compress in the fitting but seated and sealed in my first attempt.
mhaywoodcz
North Carolina
Been there done that, its a pain. Maybe the copper is better. I experienced the same frustration, kept working it until finally It seated without the drip.
Sam Harris
This is a known problem with certain kits, containing this 5th stainless line. I ended up having a hose made by a local shop (~$30), and it fit and sealed fine. It was definitely a PITA, and now the vendor (Goodridge) will send you a spacer IIRC, to correct the problem leak.
Sam Harris
My replacement PS pressure hose showed up today. Interesting packaging, but appears to be the genuine article: (all that and a bag of chips..)
Truck is running pretty ****** again. Kind of like when the O2 sensor was getting lazy. Does anyone see anything strange? I just realized I didn't get the other O2 sensor.
Walchit
Drove it to pick up my nephew about 30 minutes away. When I stopped at the gas station it had 0psi at idle. Service engine light started flashing on the way back, had 20-30ish psi driving. When I pulled up to pay the toll it died. Barely got it started, and it's knocking pretty good. Somehow made it back to the house.
That sux. Now what?
Walchit
Guess I'm gonna build a motor. probably couldn't even get my Moog money back if I sold it. My dad has a 5.3 in his truck that got rolled, but he said it had 0psi for like 5 minutes too.
It was the first longish trip we have made since we got the alignment. It rode really nice at 80-85 which I guess is a plus
At least Gen 3s are plentiful and cheap! Any idea why she lost blood pressure?
Durobans
