Tips/Advice from anyone that has replaced control arms?
ross reynolds
I’ve done a couple of these in the driveway and they’re not that bad. As far as parts go, I do everything at the same time. Inner and outer tie rods, etc.(it will help to buy a tool for installing the inners). To save some dough though, remove the upper and lower control arms, take them and your new ball joints to the machine shop and have them press the old ones out and new ones in. Then reinstall control arms. It costs me about $10 per ball joint.
Apach 031
Hey guys. I'm in the middle of doing the lca's in my 08 Yukon Denali right now. It's got the aluminum lower control arms. I've broke the ball joint loose, but I can't seem to get the lower ball joint out of the knuckle, because the axle assembly is blocking it. Does that sound right? The few videos I watched didn't mention it. Is the axle shaft a bear to remove from the knuckle?
My first post, so I apologize if this is rambling, or wrong.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Yep axle shaft has to be moved out of the way. Here:
Apach 031
Yup. That's the video I watched. Just realized why I was caught by surprise...it's a 2wd! Lol. Don't know why I didn't spot it the first time. Anyway, thanks for the quick info, 89suburban! Worked like a charm.
Durobans
