2000 Z71 shut off while driving
Stodd_17
No crank nothing lights come on. I was going down the road and it cut off, cut back on got another .5 miles cut off. Nothing. Plugs and wires replaced just last week. Distributor replace 1 month ago. Any ideas?! When I went to look under the hood one of my plugs came out popped it back in still nothing. 2000 obs Z71 limited was running completely fine before.
PNWYukon
Olympia, WA
Spark plug popped out of the engine?
Any check engine light?
Is this the first time this has aver happened?
Only after doing plugs and wires?
GMT800 2005 Tahoe Z71
Navy Supporting Member
Well, if it will not crank, you need to start there. Check for loose/dirty/corroded battery cables and follow all the way to the starter and check wires at the solenoid. Could also have an ignition switch problem and inspect there as well. Look inside the distributor to check wires at the pickup coil and check that module in there.
Welcome to the forum.
S
Stodd_17
Yes popped out from distributor
Codes for P1336 P0452
Crankshaft sensor replace 2 months ago
First time and yes only thing I’ve done to it
Conedaddy
