2012 LT lift gate problem
S1W99
Lift gate opens from FOB and ceiling button. But, it opens about 1.5 feet then goes right back down.
After reading several threads I'm assuming it's the struts need to be replaced or the motor or sensors possibly.
Is there any way to know which of these are causing the issue?
Ty
St. Louis
Maybe try help lift it when it's opening with light pressure. If it goes up all the way I'd suspect bad lift struts
S1W99
S1W99
I tried that, actually takes a lot to push it up so it doesn't come right back. Attaching a short video.
S1W99
S1W99
Anyone have the OEM part #'s?
S1W99
S1W99
Module (brain)
GM#20821156 $249.87
Module Arm includes- motor and bracket bracket
GM#23190708
$701.98
Motor
GM#23142260
$215.81
Rod
GM#15836293
$65.03
Thank you!
brice715
