2012 Yukon Denali won't try to turn over.
Kurt Johnson
Our 2012 Yukon Denali was running perfect. Took it to the detailer and they said it wouldn't start. Battery is charged. Also the rear hatch won't open now. It's almost like the vehicle won't let it start because the computer thinks the car is in gear?
Anyone familiar with this issue. Everything lights on the dash as normal.
Thank you!
GMT800 2005 Tahoe Z71
Navy Supporting Member
Theft deterrent causing problems. Might try taking the battery cables off and wait 1 minute and then touch the cable ends together and reinstall and see what happens. This is just a WAG.
Thank you!
What did you take it to the dealer for? They ought to put a Tech-2l on it and find out what's wrong.
The "detailer," not the dealer! LOL
Kurt Johnson
Kurt Johnson
Sorry. The detailer (car wash detailer) discovered the issue while they had the Yukon. We towed it to a Christian Brothers franchise and they couldn't figure it out because the diagnostic tools they use wouldn't show anything at all. We then towed it to a dealer. They are trying now.
So the rig started when they pulled in to do the detailing and then would not restart to get it outside. This statement is a bit off then," Took it to the detailer and they said it wouldn't start." Made it sound like they never got to do anything to it because it would not start to pull inside.
Kurt Johnson
Kurt Johnson
Does it help to diagnose the issue knowing whether they were able to wash and detail the car?
They washed the car pulled it out of the car wash to vacuum and clean the interior. Presume they turned it off at this point. When they finished detailing the interior it wouldn't start again.
Yes it helps. They are the ones in possession of it and their steps of care can be the difference or maybe not but it can be important what they did while they had it. Common sense.
Yes, as Ron mentioned, they very likely did something (not intentional) that disabled the car. Failures completely unrelated do happen though as Ron and I have both experienced when we had shops! We usually got the bill when it was Mr. Murphy's fault!
wsteele
Frankly, reading the description of the events, my assumption wouldn't be the detailer did something wrong.
My assumption would be a BCM failure. But in any case, the dealer techs will get it sorted.
Chelsey22
Did you ever find out the issue my car is doing the exact same thing after going thru the car wash
Capybarbro
