Help! 03 Tahoe and ac compressor won’t kick on.
NFunderburk
I recently purchased a 2003 Tahoe and the ac compressor won’t kick on. I can turn it on by jumping the relay and get it to kick on so I know that it works. It has a a small leak around the evaporator core but is it me or am I just missing something?
If there's a leak in the system and if all the freon--or is below the minimum--has leaked out the compressor won't kick on. Are you sure it has a leak where you stated? Evaporator core in the dash?
NFunderburk
NFunderburk
Yes, it’s from the evaporator core in the dash but it’s leaking at the firewall. I sprayed with some soap water and saw the bubbles. I know that’s probably not the preferred method but it’s all I had at the moment. I also made sure to closely inspect and make sure it wasn’t the lines leaking and it isn’t.
I just replaced mine, also an 03. Instead of removing the dash, I found a hack to replace it on YouTube. It took my son and I about 2 hrs taking our time.
NFunderburk
NFunderburk
Yeah, I’ve found a hack on that as well and plan on doing that. I just hope I don’t have an electrical issue hopefully it’s just the Freon in so low it won’t kick on.
jwth
Michigan
did you check the outside air temp sensor behind the right hand headlight?
veteran111
