2007 Tahoe Power Lift Gate not working
Trailblazzin
Lancaster PA
My power lift-gate is no longer operational. The only way to open it is to hit the button and manually pull it open. But to do that i can only open about 3-4” and then required to pull through some resistance and then a pop that allows it to open.
I have these DTC from the lift gate module.
B153E 08
B153A 08
B396A 02
B153B 02
I cleared the codes and tried to open it with my Tech2 and get the same results. This time i got the below codes.
B1019 00
B153E 08
B153A 08
Any ideas on a fix let me know. Thanks!
BG1988
153E Description The liftgate control module continuously monitors power liftgate operation and calculates its location and direction of travel using 2 Hall effect sensors that are part of the liftgate
wsteele
B153E 08
B153A 08
B396A 02
B153B 02
B1019 00
B153E 08
B153A 08
Have you turned off the power lift gate on the center console switch (put it in manual mode). When you do that will it open and close normally (manually)?
wsteele
On the codes, just cut and pasted from the shop manual:
B153A
Liftgate Latch Switch Signal Circuit
LGCM
DTC B153A
B153B
Liftgate Open Switch Signal Circuit
LGCM
DTC B153B
B153E
Liftgate Position Sensor Signal Circuit
LGCM
DTC B153E
B396A
Liftgate Motor Control Circuit
LGCM
DTC B396A
B1019
System Configuration Error
LGCM
DTC B1019
SDM
DTC B1019
Just Fishing
Can't fix stupid
Utah
Looking in the factory service manual, skimming over those codes.
I see that a bunch of them show up as "Short to ground"
Might not hurt to check over the wiring harness.
if you happen to have a tech2, it might be handy to go through the special functions of the lift gate and manually activate each one to possibly narrow down where the issue is.
For my liftgate, just dicking around with the tech2.
I found out where the installer pulled power for the aftermarket backup camera.
The Liftgate! :jester:
Just Fishing
Can't fix stupid
Utah
I hope you can read this, I have to reduce the size of the image.
carman2197
