Suburban towing stuff
jniolon
did my first real trailer trip towing my truck this past weekend and was generally pleased but found several things I need to address.
first... the rig is
2008 Suburban 5.3 L 4 speed auto with 3.73 axle and 20" tires
towing package installed stock from factory
GCWR is rated at 13,000 (from the manual)
Stated max trailer weight is 7,000 (from manual)
trailer is a 18' Anderson car hauler weighing 2,400
Load is a 53 F-100 weighing 3,840 with the engine end ahead
of the first axle... (truck front end weight is 2300 per the county scales)
total trailer load 6,240
163K on the truck and 30k on engine.
I did the bathroom scale tongue weight thingy and got
575 # without my wife's mobility scooter mounted in front off the truck
715 # WITH " " " "
I think I'm within acceptable tongue weight range either way. But defer to wiser minds
While on a trip to Tennessee I encountered several large hills in North Georgia and Tennessee. On the normal rises and falls the rpm ranged from 1900 to about 2300 with trailering option on. On the steep hills the trans would kick down a gear or two and rpms were around 4000-4200. During those times I’d get dings and a display on the Driver info display that traction control was off, service traction control and Stabiltrak was off, service Stabiltrak system and a check engine light. It would settle back down after topping hill and was fine on normal roads. I checked codes on return and got a P0300 (misfire) code.. I cleared that and haven’t seen a check engine light since then… this happened several times over 600 mile round trip I did the tow with just the stock receiver, no WDH... had a good bit of bounce and some sway... I've bought a WDH now which should delete those problems.
So, What would give the weird displays on traction and stabil trak when I was on dry roads.?? Is this normal ??
Thanks
john
wsteele
first... the rig is
715 # WITH " " " "
Thanks
john
It is very common when you have a persistent misfire(s) to get the Stabilitrak and Traction Control messages. They are most likely related to the P0300 Random/Multiple Misfire code.
avalonandl
Troy, MICH & Naples, FL
The first thing is to use PREMIUM FUEL when towing, second: the codes you are experiencing lead me to believe your having Battery or Battery cable issues. Stabilitrak kicks on when t senses a traction issue. How new is the battery and are connections tight?
Were you using Tow/haul mode?
When were plugs and wires changed ?
jniolon
jniolon
thanks WSteele
I had new engine installed 35K ago due to the great idea chevy had with the V-4 - v-8 mode and he did new plugs since the old ones had 130K on them... hard to believe it was a plug misfiring but I've seen stranger things... so, you think this nothing to worry about or is there something I need to do ? BTW, you have any kin around Bham, Al ??
jniolon
jniolon
Battery is ab out 13 mts old.... plugs have abt 35K on them but not sure if he changed the wires when he did the engine swap. And yes I was in tow/haul mode and I will use premium in the future ! that trip was during the Colonial pipeline hack and I was lucky to find regular... never saw any premium available
Geotrash
Dave
Richmond, VA
Could also be that your fuel pump is starting to have trouble maintaining or regulating pressure. I had the same messages in my '07 when towing, and also had the stabilitrak disabled messages. Turned out to be the fuel pump finally going out at 200K.
jniolon
jniolon
Agreed. He said he bought one in his post.
after that trip I realized I needed WDH bought a Fastway E2 trunnion bar set up 800 # TW 8000 MTW
should make a lot of difference in bounce and sway.
john
jniolon
jniolon
any real test for fuel pump problem other than checking pressure... and that is a static snapshot test and not real time during the tow, right ??
jniolon
jniolon
and I got to say thanks for all the responses... tried some other boards and one vague response from one and crickets on the other...you guys rock
Geotrash
Dave
Richmond, VA
You can use a Tech2 scanner to monitor fuel pressure in real time, and log the data. There could also be other causes though, such as a loose injector wire.
A lot of folks will replace their fuel pump proactively after X number of miles just to ensure they don’t run into problems.
wsteele
thanks WSteele
I am sure I have relatives in Bham, but I don't know them. We do breed like rabbits though... :)
I think if you can figure out what the random/multiple misfire is (P0300), you may have addressed the Stabilitrack/Traction Control messages.
A random/multiple misfire can be a challenge to diagnose when it is happening consistently. Being intermittent just makes it harder. Dave (@Geotrash) makes a good point on the possibility of a fading fuel pump. Unlike my 2007, he is right that with your 2008 you can monitor fuel pressure real time (both commanded - what the truck wants and actual - what the fuel pump is delivering). With a smart enough scan tool, you can watch it under load. There are a number of other parameters that can give you some hints, like MAF, MAP, Miss-fire counts (can help you zero in on what cylinders are miss-firing and what aren't, like if they are all on one bank (even or odd) or on both banks). That kind of thing can help you isolate the problem. If it is only on one bank, you can of put the things that might cause miss-fired on both banks aside and concentrate on candidate causes that might be bank specific.
jniolon
jniolon
you guys are way above my pay grade... my diagnostic tools are timing lights and dwell meters :). But, I've got a friend with a good scan tool and some knowledge and he might be able to give me some help. I have a cheapo obd reader that showed the P0300 and I cleared that. I'll bet that litte device doesn't do much clearing the other codes so maybe his scanner will show some stuff mine doesn't , eh ???
my question on kin ?? I've got a good friend named Steel that was from west virginia, thought it might be a cuz or sumthin
john
wsteele
john
The tool Dave mentioned above (the Tech 2) is one that can talk to the Fuel Pump Control Module and see all the various fuel related parameters, like pressure both requested and delivered, fuel trims, etc. Many high end scan tool can read the same modules. Your ODB reader might be able to see the fuel pressure sensor values. If it has an "All Sensor" mode, it will show all the sensors it can monitor If the fuel pressure value is displayed in the "All Sensor" request, you can at least watch that value. You should see about 43.5 psi. It shouldn't drop a lot from the 43.5 psi under heavy load.
You can also probably watch MAF, MAP, miss-fire counts (by cylinder). If your odb reader has a "live mode" or something like that, look for the above values. You might be able to narrow it down some.
Another thing to try as you move down the diagnostic path of the P0300, buy some MAF sensor aerosol cleaner and clean it up. There are many YouTube videos on the do's and don'ts of that process, many by the guys that make the stuff, like CRC, etc.
ScottS-Michigan
