What’s happening? Taking a nap?
Time to relocate the coils anyway to complete that million dollar look.ive got some aftermarket gloss black ones, but they use a rope style gasket not oem type and i cant seem to find the right ones. no provisions for coils on them - which i may not be able to mount coils back on stock ones with these up/forward headers anyway
thanks brother!
i see why people go thru the trouble of making up mounts/turn tables n crap... like 90% of making it look nice it being comfortable and repeatable. most of this is one big removable y-pipe so pretty crappy to lay it out so i can even weld it flat let alone run a stitch more than a couple inches. tubing itself sucks cause as you go around need to keep tip distance pretty even to get a nice weld
Nice and wide welds with good heat transfer!
I agree comfort is 90% of the battle, that thin exhaust can be a pain because it's so thin too. I kept burning holes in mine while trying to go slow and get that nice wide weave pattern.
What wire thickness are you using?
I think it's .035. I think the main problem was I didn't prep the old rusty pipe well and instead turned up the voltage to burn through the crud, in turn, it burned through everything if I wasn't careful. I dialed it back about the time I was done and it did better. if comfort is 90% of the battle then welder settings are at least 9%.
