Turn signal audible tone
Blueinterceptor
Is there a way to make it louder? At normal turns the tone is audible. But at highway speeds it’s barely perceptible?
d0wnShifT
Charleston
Same with mine. Can't hear it at highway speeds as it decreases the volume for whatever reason. I hate it and would like to hear it all the time.
gary645
Same problem - cannot hear turn signal warnings at highway speeds. They also eliminated the turn signal light in the mirrors so we cannot hear, or see, the signal warnings.
Check the volume in the driver information center or in the settings in the chevy/gmc app in the radio, chime volume (may be referred to as something else) should be adjustable and you should also have a option in the radio to automatically increase the volume depending on speed, it should also be noted in the owners manual.
B
Blueinterceptor
ive tried this. I can’t find a way to increase the volume. The fact that it goes down as you go faster, doesn’t make sense.
Vehicle Personalization The following are all possible vehicle personalization features. Depending on the vehicle, some may not be available. For System, Apps, and Personal features and functions, see Settings 0 187. To access the vehicle personalization menu:
1. Touch the Settings icon on the Home Page of the infotainment display.
2. Touch Vehicle to display a list of available options.
3. Touch to select the desired feature setting.
**Comfort and Convenience Touch and the following may display: .
Automatic Entry/Egress Assist .
***Chime Volume***
Chime Volume This determines the chime volume level.
Touch the controls on the infotainment display to adjust the volume.
that is what you want to adjust "chime volume" this will increase all chimes, including blinker sound, seat belt warning, low fuel warning, etc, etc...
in the radio settings you will find a separate setting for sounds
Audio Depending on the current audio source, different options will be available. Touch and the following may display: .
Tone Settings: Touch to adjust Equalizer, Fade/Balance, or Sound Mode. See “Infotainment System Sound Menu” in AM-FM Radio 0 148. .
*****Auto Volume*****: This feature adjusts the volume based on the vehicle speed. Touch Off, Low, Medium-Low, Medium, Medium-High, or High.
wildcatgoal
Whatever happened a good, loud relay click for turn signals? Now it's gotta be a computer bing **** bing ****. Barf.
B
Blueinterceptor
No joy in the radio settings. The chime volume raises the annoying message chime but not the turn signal indicator noise.
Hodmjstone
