LED interior light install note
dheadv8q
Oviedo FL
For the ones I bought off ebay (shipped from Hong Kong)...
I had to bend the prongs on the front and rear lamp assemblies to seat the light. In the center lamp (RSE), I had to carefully notch each side of the PC board for them to seat correctly. A serrated knife created each notch, then an Xacto knife widened and shaped it.
zach2011
Platinum Member
Mine wouldn't work right at first, they either flicked dimly or wouldn't turn on at all...but they did fit. They now all work fine, except one in the 3rd row won't do anything at all.
dheadv8q
dheadv8q
Oviedo FL
I had the same issue - oddly enough, reversing them fired them up again.
hassoun
Germantown, MD
where did you guys buy them ? ( link please or item number) im interested in turning my interior lights into white LEDs as well. thanks
zach2011
Platinum Member
Reversing mine didn't help.
Hassoun, I can't give you my link. It looks white in the pic but they're actually purple-white. I'm not a fan of it.
Conor
"Bob's your Uncle"
Seattle, WA
I have bought many leds off eBay, and yes they look cheapish, but there is not much to an LED light. Something to keep in mind is the LED's have a poss side and and neg side. So if it will not work, pull the bulb out and switch it around. If that does not work you probably have a bad bulb.
yukon07Artic
Dirty South ATL
AV2TA
Houston-Sugar Land, TX
I just changed my lights out this weekend. I like them, but think they are a little too blue/purple and less functional than the OEM. A whiter color would make the lights more functional.
Fast55
Ventura County USA
Spend a couple more bucks and get them from V-LEDS. Twice the quality of the E-bay bulbs. Mine are white, not purple, but they have those too if that's the look you're after.
SabrToothSqrl
Led
LEDs unlike regular bulbs are voltage specific.
LEDs need a + and the - connected correctly.
so flipping them, your flipping the connection, which is why it works 1 way and not the other.
ZaZaZazzels
