Front Inner Fender Liner - Under hood Splash blocking
HD_LS
I decided to do something about the poorly designed inner fender liners that allow lots of road water to spray & splash into the engine compartment. Purchased a 36x36 sheet of 1/8" thick nylon reinforced rubber, and cut two splash shields from it. (started by making a cardboard template). Then punched 1/4" fastening holes in it, and drilled matching holes in the inner fender liner. held them together with 1/4" plastic push rivets. I'll see if I need to tie down the bottom edge better.
Now I won't feel like I am wasting my time keeping the engine compartment clean.
Are the NNBS that bad? I know my NBS liners work great.
Jason in DLH
Cheeseburger and Fries
MN
Nice! I’ve been so upset with these gaping holes as well. Glad you posted this!
Jason in DLH
MN
This is a good way to protect the part directly above the tire as well. Not sure why they leave that part exposed for all the rocks and salt to hit.
kikeap
