Parking Sensors
BatsTDK
Orange County, CA
Has anyone fitted aftermarket parking sensors to their rigs? I see tons of generic kits on Amazon and got a great deal on one for $8.
BG1988
you can get some off the Cadillac Escalade 2006 had the backup sensors you will also need the ECU reprogrammed as it's tied into the radio. I suggest taking a unit from a cadillac escalade you will also need the LED thingy that goes in the rear of the SUV
I suggest getting one from a
"jaguar" the system is quite primitive and does not require the ECU (but you will have to tie it into the back up light system...) or some sorta manual switch..
i would not get an aftermarket kit poorly made at best
BatsTDK
BatsTDK
Orange County, CA
Which year Jags?
I thought about the Escalade retrofit, but they’re slim pickings around here for those and it seems more trouble than it’s worth for a simple mod.
For the cheap one, it’s literally just four sensors, a brain box and a beeper. Just needs wiring into the backup lights. Easy peasy.
BatsTDK
BatsTDK
Orange County, CA
Which year Jags?
wjburken
Eastern Iowa
Which year Jags?
I say give the low cost ones a try. If they last, great. If not, how much are you out total?
BG1988
Which year Jags?
at lest get the OEM sensors if your going to use an aftermarket back up beeper thing i would not trust the after market sensors...
BatsTDK
BatsTDK
Orange County, CA
I doubt the OEM sensors will simply wire up to the aftermarket unit. And for $8 I’ll try my luck. $8 probably won’t even buy me one OEM sensor lol.
exp500
Funny how people are trained to trust a sensor known to commonly fail. And desire them.
New isn't always best. An $8 sensor versus a $500 scratch.....Hmmmmm.
Depth perception= the difference between a brown noser and a ********!
1948Buickroadie
