Running wires to the center console
mawaru
Does anyone know how to open up the plastic panels in the center console? I'm considering hardwiring a tv monitor to the power outlet in the center console.
I figured the cup holders need to lift up the the back plastic can be removed... Or maybe the bolts in the center console need to be removed?
Thanks!
-roland
Bigmanny
Rumor has it that auto stop start kills the power to some of the plugs in the center console. You may need to find a power source that stays hot.
M
mawaru
Yeah that's correct it does I experienced that already. Regardless I did like that you can control the outlet and power from the dashboard switch
Dogged
Pull the panel off on the passenger tunnel (pulls straight off). Right under the dash, there is a bundle of wires. The orange/yellow is always hot. I wired a 12V cig lighter to it so I can use my quick charger for my phone. Works well so far and I don't think it cycles with the auto stop.
CrackerJack135
