NBS parts that need to go: hatch glass, odds and ends of interior trim
adventurenali92
Big Bear Lake, ca
I’ve got a ton of stuff laying around that needs to go as I was just given a 60 day move out notice. Ned to clear my apartment. Up for grabs:
I have a hatch glass off a 2004 escalade, with the third tail light base intact. Glad sis in good shape, both defroster tabs are intact and working. Tail light base needs paint but it’s also in good shape. The drivers side area where the lift support mounts to the trim surround needs to fresh adhesive but a little JB weld will fix it:
3E8E6F55-96A2-44F2-A91F-E361942A727F.jpeg 368F4B54-1F44-4F1F-A71C-D6BDBD4D5A45.jpeg 54FF8631-72C7-4793-A8DA-8F887E4157D3.jpeg ED2D2E89-7DA7-4CB5-829F-CA33216E61C5.jpeg image.jpg
$50 on the esky hatch. Would not really consider shipping as it’s large, awkward, and bulky, plus I don’t want to risk it breaking if it gets mishandled in shipping. If buyer is within a somewhat reasonable distance from Big Bear City, CA, I’ll drive it and meet if necessary.
adventurenali92
adventurenali92
Big Bear Lake, ca
I also have the stock hatch that came off my 2006 Yukon. Had the plastic piece that goes across the top section, it’s in good shape, hinges and lift support mounts are all intact. Bother heater tabs broke off shortly after I bought the truck so when I removed it to swap on an Escalade hatch with the Escalade third brake light, I took the stock hatch and had both defroster tabs professionally repaired. They both work. $50 for this hatch and same would prefer not to ship. Local pickup or I can drive it buyer with a reasonable distance to the Big Bear City, CA area.
adventurenali92
adventurenali92
Big Bear Lake, ca
I have a passenger side window switch door bezel from my 2006 Yukon Denali. Swapped it out for a non wood grain bezel so I don’t need this. Near perfect condition. No scratches and all the mounting tabs on the underside for the switch are intact, as well as the screw mount for the door. $25 for the bezel and this can be shipped anywhere.
EEFCC3A3-0F4B-4ED4-ACCD-310EBCD4B328.jpeg A33619DC-B2A4-4401-B784-F4835DAA676B.jpeg
adventurenali92
adventurenali92
Big Bear Lake, ca
Upper center console grime bezel with outlets and storage pockets. I pulled it from a suburban in a junkyard, thinking to customize it for my Denali, however the mounting tabs that’s cute it in its mounting spot are different because ei have a Denali so I can’t use this piece. It’ll fit all 2003-2006 Chevy pickups and SUVs and all non Denali Package 2003-2006 Yukons and Sierra pickups. Tan in color
$30 and will ship anywhere.
adventurenali92
adventurenali92
Big Bear Lake, ca
I also just swapped out my Denali wood grain dash bezel for a non Denali dash that I wrapped. Denali dash bezel is up for grabs. It’s in decent condition though it does a small crack across the top. I also managed to break two of the mounting tabs the last time I pulled it out working on the stereo. Now that it’s out of the truck I’ll JB weld the tabs and those should be good to go. $50 for the bezel and I can ship this out if need be.
D78CF562-2274-4941-BFE3-9E8D9026324B.jpeg 578165B7-B6E1-4D0A-9E6C-19873863E5D9.jpeg B48DC587-27FA-468C-88D8-953FD5656A3C.jpeg 87B70ED3-698C-4941-8CFD-DDC0A7A0136B.jpeg AA37FE7F-D4F0-459C-BF69-73FB7A71592C.jpeg
adventurenali92
adventurenali92
Big Bear Lake, ca
Fixed the broken tab on the dash bezel with JB weld plastic bonder. It’s solid. Need this bezel gone, someone make me an offer on it!
adventurenali92
adventurenali92
Big Bear Lake, ca
Got a set of halo headlights here that need to go. Will fit all 2000-2006 Yukon models and all 1999-2006 Sierra pickups. The halo rings and the LEDs all work perfectly. Working is in good shape. Make me an offer on these! Local pick up or can ship them out.
7837C111-7862-4006-BC83-A8CD9EA4F37F.jpeg 1474A4D6-952F-4370-943D-A531A24A7863.jpeg F28D0676-1807-45EA-8BE9-ED0612DF2105.jpeg A6A96F38-D0D1-4100-9E9B-04631505B3CC.jpeg EA1892A4-7192-4B79-B8C5-AC106695DE07.jpeg
adventurenali92
adventurenali92
Big Bear Lake, ca
Found a pair of Escalade headrests. Grey leather. I pulled these awhile back out of a junkyard caddy. Not sure why. Lol. Dusty but otherwise in perfect shape. $25.
KonMan05
View attachment 258457 View attachment 258458 View attachment 258459 View attachment 258460 View attachment 258461
Hey how would I buy this from you?
Merch619
