Throttle body relearn
Kenny D
Crosby, Tx
I cleaned my throttle body and did the idle relearn but if idling in park at 600ish, I can tap my throttle and the idle shoots up to 3000 and takes forever to come back down unless I hold the brake hard and put it in gear, then it'll drop down and then go in gear. . Whats up with that? I got a trip to go on Friday and need it not to screw up on me
PG01
Up here to the right
Hey kenny... give a few days with stop and go driving with highway and it will get back to normal... it’s gotta relearn. there is a procedure and it has to be done before you key on or something
Kenny D
Kenny D
Crosby, Tx
That's what I gather, I did the idle 3 min, off 1 min, idle 3 min.
drakon543
the initial relearn is just so the computer can learn how to keep the engine running and operating. after that it has to relearn how to run it efficiently again.
Jetav8r7
Edmond,Oklahoma.
Don't ever ever ever. touch the throttle body unless you absolutely have too. i drove my for weeks cause a lot people said they same. and it NEVER!! came down. finally I took it to the garage down the street for $50 and less than 5 mins they had me on my way. i have 387000 miles. and she runs great.
PG01
Strange, I just did mine the other day and its fine...... hmmmm
Idriveaho
I cleaned mine after doing the sea foam spray that uses the straw that your put in the air intake before tb. I too had issues with high idle even after driving for 30 minutes around highway speeds. Did multiple relearns. Eventually by the next day after using it it was getting better then back to normal. Just drive it.
GS Audio
