Anyone actually use these trucks for off-roading? I'd love to hear feedback/experiences...
cheyenne383
Far North Lurker
Healy, AK and NE GA
Amazing pics! - Thank you.......What year is your Burb? - and which tires are you running?
Thanks, pics really don't do it justice... there's so much space up here the views never get old. I ran BFG KO2s for 65k miles until this summer. I switched to Toyo A/T3s and like them so far, I did poke a hole in one already though and never did with the KO2s... so we'll see how long they hold up. Better mileage (12 lbs lighter each) and less noise, this is my wife's daily so she's much happier without the E load range All Terrrains.
I run KO2s in Load Range C; definitely lighter and have a patch in 3 of them at 50K miles. While some of the nails were big, none made a big enough leak to cause a tire change or even set off the TPMs until a few days went by.
GreyStone
I was originally going to go with KO2s - but in my size everything was D and E range. I kind of like a gentler highway ride - Tahoe is about a 4.5 hour drive away.
cheyenne383
Far North Lurker
Healy, AK and NE GA
Well here's some feedback on the Toyo A/T3s... they don't hold up to gravel well. They do great in the rain, are very quiet, and my mpg has improved significantly over the E load range KO2s but this is the second hole a rock has punctured through the tread of the A/T3s. I would say they're great street tires but not meant for hard use, I know I live in a unique area with demanding roads but I am pretty disappointed... I should have trusted my gut and stuck with the BFGs that have done well for 10 years up here without a single puncture.
Here's the carnage... the hole was too big to plug so the tire with 8k miles is garbage... we'll see what Toyo says this week.
At least the trip was otherwise a success... gorgeous fall scenery and a great getaway for a couple days to explore McCarty and Kennecott, Alaska.
GreyStone
If I lived in AK I would not run a tire below load range D - probably better off sticking with E range up there.
cheyenne383
Far North Lurker
Healy, AK and NE GA
Oh, I know... trust me... this is the wife's daily and headed to Georgia soon is the only reason the same tire spec didn't stay on it. I wish I could have held out replacing the KO2s until it's back in the southeast this winter but at 65k miles they were about toast and terrible in the rain (which we get a lot of in the summer).
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Amazing pictures, so would love to see that in person and make a drive out there on those roads.
cheyenne383
Far North Lurker
Healy, AK and NE GA
@cheyenne383 That looks like more than just a "rock" punctured through...... Beautiful pictures though, thanks for sharing.
Yeah, it must have caught it just right... here's the culprit, the plug went right through it :nolol:
It has definitely captivated me... Alaska is like no where else I've been! Bring a spare if you drive up :anitoof:
nglauer
Well... I tested out my Duratracs really well today. We have timber crews currently working one our transmission line right of ways, they mucked up the access road and created a massive mud pit at the top of a fairly steep incline. I started up the access in 2wd (it was nice at first) and quickly realized I was about to head back down the hill once I got into the red clay they had turned up. I had to put it in 4x4 quickly to regain traction before I ended up needing a D9 to pull me out of a ravine. Ironically, they had to pull a super duty out that was really stuck. I didn't get pictures of that side of the right of way mainly because I would have disappeared in the mud as soon as I got out of my Tahoe. Luckily, I was able to push through everything (4hi only since I don't have the 2 speed transfer case) even though I was pushing mud with what I hadn't cut off the airdam. Those running boards will hold a LOT of mud. I can only imagine what the undercarriage looks like... I did get to snap a picture from the other side of the valley from where I was earlier (I made it to the top of that hill from the other side). The excavator is a John Deere 320 for reference. I also checked out the covered bridge near another one of our new access roads. It's currently closed to vehicle traffic, but will hopefully be reopening. Pretty amazing seeing the dates and names carved into it.
A little history:
The Hune Covered Bridge is a historic wooden covered bridge in the southeastern part of the U.S. state of Ohio. Located northeast of the community of Dart,[1] it spans the Little Muskingum River in northeastern Lawrence Township in the eastern part of Washington County.[2] Local bridge builder Rollin Meredith erected it in 1879,[1] using the Long Truss style of truss bridge design; the single-span bridge was named for the locally prominent Hune family. Among its design features are a metal roof, abutments of cut stone, and vertical siding. As a Long Truss, the Hune Bridge is a valuable example of nineteenth-century architecture: few examples of this complicated style survive to the present day.[3] In 1976, the Hune Bridge was listed on the National Register of Historic Places, both because of its place in local history and because of its historically significant construction.[1]
History courtesy of wikipedia
Sent from my SM-N975U using Tapatalk
A little history:
Pretty cool bridge. Seen any old(dated)graffiti?
nglauer
Yep, there are names cut into it all over the inside. I saw a few that were dated around 1920. I imagine there are quite a few older ones. This is 1 of 3 covered bridges local to me here in SE Ohio. I'm pretty fortunate to be working close to my home.
That's pretty cool. I'm sure there's a few "Kilroy was here".
ASG-MikeS
