Mezzo
Me too, hope you find one soon , it really cleans up the rear. I have an extra but it’s off an ext :smh:
well the lettering is actually off 07-14 body. The bowtie is off same gen impala trunk lol. Had all these in my tool box for a few years now.
yaaaass feed the trolls :signs6:
so I finally retired the infamous HOE badge View attachment 256819
I thought they were compatible,i learned something new.
mattbta
Frisco, TX
:rage:
Drove the thing less than 50 miles since putting the replacement of the refurb head on. It's leaking at the freeze/expansion plug on the front.
Onebad1983
Resident Country Dumbass
Good for you, hope you have a great career! I spent my last 3 years of HS ( back when they taught it there ) taking auto mechanics and 2 years at a trade school for it. Ended up as a pool mechanic for 7 years, then worked at a pool distributor for the next 30 years. I should have stayed in the auto field
Thank you sir!
Mezzo
The end of an era.
DougAMiller
Colorado
Came up with a solution for those ridiculously expensive puddle lights that break no matter how carefully you try to remove them. I know a lot of you guys have had the tab that holds them in break off, but I came up with a simple fix for it. I took a 1/4 inch wide strip of stainless steel sheet (if you have any old 3.5 inch floppy disks still laying around, many of them used stainless for the sliding port cover, that is what I used) and bent it into this shape.
Then I glued it to the side of the light where the broken-off tab was. It pops in and holds it perfectly, and with that short tab at the bottom, you can catch it with a flat screwdriver and pull the tab in to remove it. Best part, it didn't cost a dime and works just like it should.
Got a pic of yours?
Sam Harris
Nice!! Thanks for the tip!
brice715
