Rear Sway Bar Hard To Find?
JimHanus
Richmond MI
2013 Tahoe stock suspension. Looking for a stiffer rear sway bar than stock. I've found a couple but they seem excessively priced. Does anyone have a recommendation on a reasonably priced rear sway bar? Nothing fancy, just better handling. A few of the links I followed here didn't work (too old I guess). Thanks!
Jim
HiHoeSilver
Away!
Chicago
Jim
The typical go-to's are Hellwig or Eibach.
Dantheman1540
Sugar Loaf Mountain
They are all expensive it seems. Rears always seem to cost more due to size I suppose. I have a hellwig and like it. I don't notice a huge difference when cornering without a trailer as the front desperately needs a bigger bar but when towing it really helps keep trailer sway away.
StatutoryAPE
Peoria, Az
I ordered Eibach straight from their site. It was pricey. But I highly recommend it. It's much bigger than the OEM bar. I also recommend getting front and rear at the same time to save on shipping costs, only if you ever plan on doing the front in the future. Just do em both and get it over with.
J
JimHanus
Richmond MI
Good to know. Do you feel a significant difference from stock?
It corners better, doesn't lean as much. I don't notice any difference in the ride quality. It was worth the money. Only problem I had installing was the holes in the supplied bushings were too small for the mounting bolts so I had to drill them out slightly. The bar is solid, not hollow, and weighs about 24lbs.
Ruben03yukonDenal
