Some ticking while starting.
bigrhino
l.e.s manhattan,nyc
i have a 2011 Tahoe. Sometimes when starting the engine, a get a ticking sound. Sometimes it starts right up, sometimes it won"t start until after a few ticking sounds and sometimes it won"t start without a jump. I tested the battery and alternator and their good. Could the starter be on it's last days?
GMT800 2005 Tahoe Z71
Navy Supporting Member
Sounds more like the battery and/or connections at the battery and starter. When you say the battery and alternator tested good, how did you test and did you first inspect for tight clean connections? What are the test results that you got? So many times members say something tested good and then we find out it did not really test good but the ember THOUGHT it did.
If it always starts with a jump, that seems to me to rule out the starter.
BG1988
relay might be broken check the relay
jz57
Check the solenoid on the starter
PG01
Up here to the right
Remove your battery cables and completely clean and inspect them, they get funky on the inside under the plastic.
79jasper
Sometimes the extra amp capacity helps a dying starter along.
Hard to say without actually hearing it. Wonder if the starter is hanging.
B
bigrhino
l.e.s manhattan,nyc
Update. I tested the battery again and the meter was reading 65% before starting it. I usually start it every other day, but lately I’ve been staring it every day for about ten minutes and so far no problems. Thanks again for everyone’s help.
GS Audio
