Opinion on OEM Wheels - 2015 Tahoe LT
nglauer
Hello, first post. I found a local dealer with a higher mileage 2015 Tahoe LT. It's a fairly clean rust and dent free Tahoe with 131,000 miles. It currently has the polished wheels (shown on it below), however I asked the dealer if he would swap wheels off a truck he has on the lot. They are the black 18" factory wheels with new Goodyear duratracs. I work on power line right of ways and wanted something slightly more aggressive. I didn't want to buy it then have to go buy tires as well. I also wanted a Z71 package Tahoe, so I figured this would be a decent compromise. Opinions appreciated!
Sent from my SM-N975U using Tapatalk
GreyStone
what size are the tires on the black rims - if they are too large they will rub. If they do fit and you want the truck - I think the swap is a good idea. 15 was the 1st year of this model run - sometimes the 1st year vehicles can be a little buggy. Make sure the A/C works correctly. GL
SARNCAN
My opinion is to skip the 2015 LT and look for 2017 Z71. This one got high milages and those 20’s are more expensive than the 18’s to swap. With the Z71 you’ll not only get the 18’s, but good ground clearance at the front and a 4 wheel drive. 2017 models have Apple CarPlay and Android Auto as well.
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
Nice looking truck. You will have a love/hate relationship with those duratracs. They will never let you down but you will always know they are there. I had a set and they were freaking great in the snow and off road. They were also loud and you knew they were there.
nglauer
nglauer
that’s a lot of miles for a 5 year old truck.... was it a fleet vehicle or rental?
I'm not sure on its history. I would assume fleet, but it has an aftermarket DVD player on the ceiling.. so it's hauled passengers. Although it doesn't show any signs of "small" kids being in it. Then again, maybe my kids just leave a bigger trail than most.
nglauer
nglauer
It is high mileage, I agree. However the price is right and it is going to spend 90% of its time on our AEP Powerline right of way roads. I don't plan to lift it, but most likely level it and add the OEM aluminum/steel skid plates since they seem fairly inexpensive. The wheel swap was only to save me from running to buy 20" all terrain tires. I also like the look of black on black.
Welcome to the Forum from NH.
Decisions, decisions.......
Do your homework, make the decision, and run with it.
If/when you need assistance, folks are here to help. Communications here are two-way, so we expect you to contribute to our collective knowledge base, as well.
nglauer
nglauer
I pulled the trigger on it today. Loving it so far. I plan on having the local Chevrolet dealer pull records on it. I'm curious what has been done as it appears to have been taken care of.
Super!!!
GreyStone
pics or it didn't happen! ~ Right on Bro!!
nglauer
nglauer
I'll get one once it's cleaned up. It seems to run good, but the duratracs are rougher than a corn cob.... and I love it lol.
I assume this has cylinder deactivation. I have noticed that it makes a weird sound and feeling as if I'm hitting rumble strips on the edge of the road momentarily. I can see the tachometer raise RPM for a split second. Is that from switching from 4 to 8 cylinders, or do I need to investigate into a possible transmission related issue? it also shifts into gears like it has a shift kit. It almost reminds me of the trans am and z28 I had built transmissions in back in the day. Either way I have a 3-year 36000 mile warranty so I won't be heartbroken if the transmission has to be replaced with a new one LOL
GreyStone
try putting the transmission in M5 and see if the rumble sensation goes away.
nglauer
nglauer
Welp... That was short lived. Apparently what I was feeling was the transmission on its last hoorah. It started shifting weird today and making an odd noise (owned it less than 24hrs). I happened to be near the dealer I purchased it from when it decided to get stuck in what I assume was 4th or 5th gear. I went ahead and limped it there and their mechanic gave it a quick scan and reset everything. He said it had a BCM communication code? (I believe that's what he said) and assumed resetting it would fix it.
It did, kind of.
The lot is next to a GMC dealership that some good friends of mine work at. I went ahead and drove it over and had them do a quick recall fix on some type of braking issue and had them reset my tire sensors from where they swapped wheels for me at the other dealership. They printed out all the GM service records for me and the mechanic went ahead and did a quick computer check with a GM Scan tool as well. He thought what I was feeling was most likely the 4 to 8 cyl deactivation/reactivation causing the rumble.
Welp... it wasn't. I got on the interstate set the cruise to 70 and made it about 4 miles without issue. Then I assume it lost a gear and revved to the moon. The D for drive started flashing and I wasn't able to get it to shift manually/electronically. I got super lucky and coasted just far enough that I rolled into a rest area. I called the dealership and the owner (they own a really nice towing company) sent a rollback immediately to me and brought me back to their lot. I guess I'll know more tomorrow. I know the owner and he felt horrible, and even have me the keys to his personal vehicle. I refused, but I have no worries they'll make it right. Plus I opted for an extended warranty through my credit union. No clue how it works, but it is through Route 66 (main street coverage). I guess on the bright side... maybe they'll put a new remanufactured transmission in it. I'll update the post once I know.
Nick
MicheleY
See if the AC has ever been repaired, specifically condenser. I have a 15 LT and my AC just died. $1800 to replace condenser and rear lines. After some research, I discovered the 15-17 have this known issue that was a defect. A lawsuit was also brought on, but GM won't do a recall. They extended the warranty a bit, but most were out of warranty. A lot of pissed off 2015-17 Tahoe owners... me included. Wish I had researched the year before buying. The AC should not need to be replaced at 5 years. I bought mine a year ago. I considered trading it, but I do love it. Just going to suck it up and keep my fingers crossed we don't have any other issues.
BMPNUGLS
Mid-MO
The early year new body styles (15’s - 18’s I believe) have had numerous transmission and/or torque converter issues - most often it’s a torque converter that’s went bad....and if so it most likely spewed stuff into the transmission via fluid exchange etc. Some issues are very slight due to the transmission oil GM used from the factory - most dealers will do a flush and replace with higher viscosity Mobil1 oil (but yours I’m sure would not be a candidate for this ‘free service’ due to the mileage). Mine had the slight ‘rumble strip’ feel and kept feeling ‘weak’ especially when towing a bass boat...the fluid flush and refill with the Mobile1 seems to have fixed the issues I was having going on 5-6 months now since the fluid exchange...but I may have just caught it early enough to avoid any serious damage. Just my $0.02.
nglauer
nglauer
I called the mechanic but haven't heard anything back yet. I assume the complete transmission is done for, it appears to have lost all gears. Hopefully the insurance I bought and the dealer can take care of it.
HVAC - I suspect it may have had the condenser replaced. I can see where the plastic cover had been removed in the past and the condenser looked fairly clean. If it breaks, I have all the equipment to fix it myself. No way could the HVAC system in one of these be worse than a 2010 GMC Acadia. Our Acadia has been a great vehicle but it is nearly impossible to work on the HVAC system.
Thanks!
Nick
nglauer
nglauer
Dealership is searching for a remanufactured transmission with a decent warranty. They are hoping to get it and install it the same day it comes in. I'll update everyone one it's here.
91RS
GA
The GM transmissions will have the best warranty because it can be used nationwide at any dealership. Three years unlimited miles.
Hodmjstone
