Lifting 2003 Yukon Denali
redneck24v
I am new here, but am trying to find information. Is it possible to lift an 03 yukon denali with z55 autoride more than just the shackle lift and coil spacer, Im looking to lift it 4-6", if it can be done, where do I find a lift kit for it??? thanks
Repo503
I won't pretend to know a whole lot about suspensions but I know this can be done. I'm pretty certain nobody makes a kit to lift it like you're looking for, I'm pretty sure you'd have to piece together seperate components and from what I've been told it isn't a cheap. Like could buy a second truck not cheap.
BlizzardX23
Sacramento, California
Yes, theres a few lifts that could be purchased to lift your Denali...I will look for the websites in a little bit and post links...but right now, Im gonna run out and get Jack In The Box real quick...so brb
R
redneck24v
Im really just wanting to fit 33's under it, could it be done with some kind of a leveling kit for the front? and leave the back stock? It is the AWD.
BlizzardX23
6 inch lift by Pro Comp with 35 inch tires
http://www.roughcountry.com/Chevy_99-05_6EXin.htm - 6 inch lift with 35s
15 inch Full Throttle Suspension
05Yukon
Houston
You dont need a 4inch lift to fit 33's. Are you wanting to run 285/70/17 or a true 33? If you want to run a 285/70/17 you only need keys and spacers. The autoride is definitely a pain in the ass when it comes to these trucks. I would make sure what ever you do isnt going to put anymore stress on those shocks as they are no cheap.
R
redneck24v
a 32.whatever would be fine, im not going to mount on a factory rim, would probably go with an 18, but do i really need a rear spacers, I was hoping to not even mess with the rear end.
AquinoSteven
Key and Spacer Guru
Clinton, NJ
to fit 33s your gonna need keys and spacers. Ford F150 keys will give you 2-2.5"s. Spacers range anywhere from 1 to 3"s. I would go with a 1.5" spacer.
Ford keys
1.5" Spacer
17 Addicts
33s
R
redneck24v
will the spacers not affect the autoride or have any hindrance to them?
BlizzardX23
yes...they will...your talking about coil spacers? or a body lift?
with a body lift, no....they wont affect the AutoRide
with coil spacers, yes, they will, you will have to get longer links...which I can cut for you and mail in a regular paper envelope if you want.
AquinoSteven
Key and Spacer Guru
Clinton, NJ
yeah, im not to familiar with autoride but it looks like Blizzard has the answer. I say go for it.
BlizzardX23
Well...It would be a test situation as I have never made longer links...I made my shorter links and they work perfect though so I can use the same math and make longer links...or you guys can do it if you want...I just already have the right size metal rods.
The stock links are 4 inches long. For every in lowered, you much cut 1/4 inch off the link. For ever inch lifted, you must ADD 1/4 inch to the link
So if you add a 3 inch lift to your truck, your stock 4 inch links must be 4 3/4 inch long...since you need to add 3/4 inch after lifting truck
Nick05LT
NOR*CAL
Sorry to bring up an old thread but how did this turn out and what size rod was used. I'm looking into doing the same thing with my 05' hoe.
isenegger
victoria, tx
Ford keys
1.5" Spacer
17 Addicts
33s
that looks good. i want that stance. are these the green keys? what size tire is that?
D Rollins
