So, you can't pull the pan, to access the pump?
I was told it was probably too late. I actually have another motor, I just have to buy the usual--knock sensors, gaskets etc. I think I just rather do that instead of paying to replace the oil pump and related gaskets, only to find out it didn't work. For a motor swap, my buddy charges $500 just for labor. That's including getting it to run. I know to do the oil pump would be at least $400 just for labor--since I can't do it myself.
mountie
Seems like what I did for my old '88 GMC truck..... At 220,000 miles, I needed a valve job ( valve seals were bad)...... My mechanic told me to get a 350 cid, 4-bolt main for the same price.
That engine was fire breathing all the way 'till I sold it with 392,000 on the clock.
mountie
Tony, I found your engine ( twin turbos )
YukonXL04
The Riverboat
Arlington, TX
I started mine the other day... been about a month lol. Wife got a new suburban so this one has just been sitting as a backup vehicle.
04 with 122k miles ain't bad hahaha I do need to go drive it some though
Bombsquad85
Northern VA
Well I have about 7 codes showing up including 3 codes for Bank 1 Sensor 1 O2 sensor, MAF sensor and Knocj sensors (again) . Trucks running like a pig and I'm getting shit gas mileage. Bit the bullet and got a new 02 sensor, maf and know sensors and harness again
Did it help?
mountie
Been at work forever. Not much time for anything . Installed my new plates a month ago lol. Still getting snow even today . Not a fan of 7 month wintersView attachment 243902
Me, being from west Canada, and lived in Kalifornia,.... I learned to VISIT the snow..... only visited Big Bear Lake, Lake Tahoe & Frisco, Colorado......then got the hell outta there!
But, that photo shows a nice contrast to your Tahoe.
05Single
afraid of the dark
im good with 2 or 3 month winter. But I don’t even want that anymore. I’m sooo over it:nono:
Bombsquad85
Northern VA
So parts came in earlier than expected. Bank 1 sensor 1 O2 sensor was a ***** it get in. Had to have my wife help because my arm was too big to fit between the exhaust and driveshaft.
MAF was a breeze.
Got the new knock sensors in. Built the dam higher this time. Also found out that I had a pretty big oil leak from the oil pressure sensor so I cleaned and tightened that. Turns out that my socket didnt fit fully around the sensor without removing the valley pan bolt closest to it...
Removed the valve covers and thoroughly cleaned them. Tomorrow the harness for the knock sensor will be here and I'll put it all back together. Hopefully no CEL this time.
I was gonna paint the valve covers but decided against it.
20200404_165953.jpg 20200404_165940.jpg 20200404_170024.jpg 20200404_182320.jpg 20200404_170030.jpg
MAF was a breeze.
View attachment 243912 View attachment 243913 View attachment 243916 View attachment 243918 View attachment 243919
I'd just scrub the vcs clean with some degreaser.
Bombsquad85
Northern VA
That's what I ended up doing. I used a bristle brush with some simple green. Once the majority of the grease was off i used some long tipped cotton swaps for the grooves and tough to reach spots and a wire brush for the stubborn parts. They arent perfect but they look 100x better. Maybe some day I'll pull the motor and give it a solid clean up... inside and out
JohanZ
