Speakers not working
Rosson03
Kentucky
So I take my door panel off in the rear and thought it I blew a speaker bought some new ones and plug them up and still nothing anybody have an idea there's a lot of static on the passenger one before I removed it but still works I have other problems with front speakers to but right now I want to work on the rear
Please help
Aftermarket radio and speakers fyi
Rosson03
Rosson03
Kentucky
I don't have any fancy meter so should I just run a set of extra speaker wire from unit to speaker,
If that works awesome if not is radio shot, I haves it for 7 yrs almost
wont take a fancy meter, any cheap $10-15 meter from the auto parts store or harbor freight, lowes, etc will work, all you are checking is if the wire has a signal if not then it may be pinched or broken somewhere. If the deck works and it's easier to just run news wires go for it.
Rosson03
Rosson03
Kentucky
False alarm I thank everyone, I smacked the amp and speakers r working
Still like to know why it did that, is it time for a new amp, been about 10 yrs
Hard to say, it’s either a loose wire connection or something inside the amp has a broken solder joint. How is the ground- check if it’s loose or corroded where it connects to the chassis.
Tom Morgan
You list an 06 and an 07 in your signature. Was this the 06? I ask because this is the section for 00-06. I am working on my daughters 04 Tahoe where the main speakers have no output except for the front door and rear pillar tweeters. She says once when she hit a bump the speakers worked for a while, which sounds similar to you "smacking" it. If this is the 06 did it originally have Bose? You say you have aftermarket head unit and speakers, but the amp in still in the loop? Where is this amp that you smacked? Thanks for any info you can provide.
curbud
