Blurred's 04 Tahoe Z71 build - Mr. Greenly Greenerson
blurred
blurred
Puyallup, WA
So after driving this around, here's my planned changes for the future (some distant, some not-so-distant)
1. new wheels. Going to run either a 23 or a 24x11 with a -24 offset (roughly). These will more than likely be a set of forged 3-piece wheels due to strength, weight, and to get the right offset/look I am going for.
2. Fenders will more than likely be glassed to be a seamless piece, then the current fenders cut out and simply used as bracing/skeleton. This way, I can make the appropriate clearance I need for turning the wider wheels and tires.
3. Rear quarters will get glassed as well. This will require pulling the window and builing everything into one piece, again, removing some of the sheetmetal that isn't necessary while still maintaining the strength.
4. Rear doors will get glassed to make it a seamless flare.
5. hood will be resprayed or replaced with a cowl. Don't really think I can justify the cowl hood until I get a little more power to the wheels, but we will see.
6. Front bumper will be finished at some point. Merging an HD cap with the Denali lower section.
7. Side skirts will be pulled and redone. Not exactly sure on the plan for that yet.
Doing this will also allow me to make the Tahoe a little wider. It's already somewhat wide, but for that "hot wheels" look, another inch or two on each side will really make it subtly outlandish. Also, as these are distant plans, it gives me the time to do the homework in order to make the fiberglassing process simple and as strong as the sheet metal it is replacing.
Again, these are just ideas I have in my head. Until then, I need to order sway bars to reduce the body roll and the little rear suspension extension bar things (name escapes me) to re-center the axle on the wheel well.
blurred
blurred
Puyallup, WA
Oh and I took pictures yesterday. Today I buffed the body out and cleaned everything up. But I have no pictures of that. Lol
LRM_EXPORT_45522923987391_20190726_180851894.jpeg LRM_EXPORT_45516351259425_20190726_180845321.jpeg LRM_EXPORT_45558687984773_20190726_181333230.jpeg LRM_EXPORT_45575328720131_20190726_181422233.jpeg
ridin_low07
Okc
Absolutely love this truck. Followed you on Instagram and sent you a friend request on Facebook lol. You're working magic on the Hoe. Way to go
05Single
afraid of the dark
Y u no have side markers ?!!:yuno:
Or did we discuss this already ?
blurred
blurred
Puyallup, WA
So, i have not logged in for a bit, forgive my transgressions. Also, I have recently found Bumbu Rum and this post may not make sense... it's so delicious.
i appreciate it. Haven't done anything with the Tahoe since these and just been racking up the miles. Picked up an 82 gs850 that im building into something... well, something, so i can park the Tahoe and ride when i move back to Tennessee. Plan is to park it for several months and put in some serious work to really push this thing further than i already have.
we may have. I never bothered to figure out the wiring so that i can run it as a third sequence, though i might have just thought of the way i could make it work..
Onebad1983
Resident Country Dumbass
Where are you moving to in Tennessee?
05Single
afraid of the dark
He’s secretly moving even farther away from me :bawl:
blurred
blurred
Puyallup, WA
that wouldn't be a far drive to meet up with you. I live in north Alabama
It wouldn't be bad at all. I know a lot of people in Nashville area since I was there for about 14 years before coming out here to Washington for the last 3 years. And honestly, I plan to pull some big triggers on the Tahoe when I get back there and get set up. Well, might not be big on some people's radars, but it will definitely be a "why put that kind of work into THAT vehicle" type of thing. lol
This is, in fact, quite accurate.
blurred
blurred
Puyallup, WA
And I haven't updated shit on this thing other than the mileage and an oil change lol.
It needs lot of love, but I've been focusing on getting a $500 motorcycle transport ready when I move back to Tennessee. And with the impending move, I'm progressing one mod thats been sitting for a bit... not the bumper. Lol
Picked these up and so far I have 300 into the entire setup (tires, wheels, mount, and balance) and ready to bolt on. Will have some pictures a bit later of them on the Tahoe. Plan would eventually be to get these refurbished, but they will be perfect for 2400 miles i will be putting on the thing.
Keeping your old setup?
Sam Harris
Long Time no lurky.
Buford bubba
