Stabilitrak light blinking NO Acceleration
BG1988
Thanks man. I will check that out and see if mine has a button there I don't recall seeing anything but I was not looking either.........
yes there is a button to turn it off standard equipment
That just resets the light if there is a malfunction and it wont turn off. The stabilitrak "relearns" every time the vehicle is started- it does a diagnostic at that time.
dnt1010
dnt1010
Tennessee
Awh OK so if you push the button and hold it for about 5 seconds it turns the stabiltrak system completely off. Only thing is it turns on the yellow dash light. With it off though I can drift pretty effectively, I like it, great tip thanks. might look into teh actual tech2 thing later it does not bother me too much I will just turn it off when if I wish to drift.
BG1988
if you pull some fuses you can do burn outs as well.
Dropped HYbro
YES-....I have an 08 hybrid...large tire wheel combo...28 x 10-295/25/28...and this has happened several times to me as well....steep on ramps...sharp turns...engine shuts down...im thinking it has something to do with the tire wheel combinations were running in regards to angle/deflection and the stability track system...your thoughts??
09 Tahoe Hybrid 204k miles. I have had a blinking stabilitrak light on hard turns at speed and when going slow since I bought the truck several months back. I have driven it about 8000 miles. I thought it had stopped after the last front wheel hub bearing replacement was done but it still does it. The light comes on and blinks on hard turns mainly on right turns. This really gets to be a problem on a Interstate On Ramp that has a tight right turn, if the light is blinking the engine will NOT accelerate until the light stops blinking this could take 2 to 3 seconds and that creates a dangerous situation trying to merge int traffic. Obviously I can slow down to an almost crawl around the turn and the light stays off but I think it is time to look at this closer and figure out what is really going on. Has anyone here experienced this particular issue before? I am seeing 3 main components in the GM system. Yaw Control sensor / Steering wheel angle sensor /accelerometer. Both front wheel hub bearings have been replaced since I have owned it so I think that eliminates a wheel speed sensor issue? Now this Hybrid is lifted 3.5" and has oversize wheels 20x10 and oversize tires 285/55R20 so of course that could contribute to the issue. Just wondering if anyone in either stock configuration or lifted has noticed the issue? There is some data online about the blinking stabilitrak light is a normal condition but does not mention that it stops the engine from accelerating when it is blinking! I really do not care if it blinks once in a while but I need all 385 horses on line when merging! NO CODES are stored.......
dnt1010
dnt1010
Tennessee
Yes I agree it is most likely the lift and wheel tire combination. Not a major issue, more of an aggravation.
Dropped HYbro
strange issue...it seems to be happening more and more with my hybrid....least I don't panic anymore and relieved when the motor kicks back in!
BG1988
I would take a look at the ground wires as well since GM just chain linked Bare braided aluminum wire from the body to the engine then insulated Copper to the battery this could add some resistance Ω
. esp for salty areas were things get rusty and corrosion etc..
Dropped HYbro
thanks- plan on looking at it this weekend when im changing plugs and wires.
I'll post if I find the ground wire to be the cause.
BG1988
it's not just that the engine block becomes a electrical resistor it self as the engine block warmed to 105C(maybe even slightly more ) will have more resistance then at 20C..
Yes the mass is BIG but still has some extra resistance
Basically they cut the corner not running a dedicated Copper Cable to the chassis from the battery...
I plan to do the big 1 upgrade on this
Battery to chassis with #2 or #0 copper wire gauge.. )
basically the 6 or 5 AWG braided aluminium cable is the weakest link in the chain...
in order to keep electricity happy you have to give it the path of lest resistance ( but electricity will get mad if it's shorted :p )
Also i would clean up the battery if it's old as the plastic housing can be come conductive over time (like a resistor)...
Dropped HYbro
I appreciate the feedback....will you post a link to the big 1 upgrade....have heard of it just not sure exactly what it entails
...and if I can do it on my hybrid safely....when you have a chance.
thanks for the help brent!
Dropped HYbro
thought I would post pics of referenced chevy's!
HiHoeSilver
Away!
Chicago
There is not a link to the BIG 1, because it's made up. Search big 3 or 4 upgrade.
BG1988
No point in upgrading anything else unless you want to mess under the High voltage converter and if you damage the inverter it's pretty expensive to replace..
You will need to find an electrician that is qualified in High voltage applications..
This is 330volt AC and 330VDC and 48+VDC
but it could use a beefed up Positive Cable as the 12+VDC output is rated for 185AMPs...
also you would be replacing the two 330Volt (3 cables aka 3phase) the 330Volt DC cables the 48Volt cable (for the power steering)
and the 12V+ cables it would be the big 9 upgrade lol
also the 3 cables from the transmission so were looking at 12-15 cables that can be upgraded
dnt1010
dnt1010
Tennessee
Big issue Brake system issue just started today. Complete loss of Brake power boost. Code that popped up is C12D8. Only definition that I can find online is "ABS Base Brake Open Solenoid Driver Shorted" ABS / Brake and Traction control icon all lit up on the dash and loss of brake power boost. Not sure if this is related to my original stabiltrac issue or not. I have been looking on the internet for hours for some additional information.
Looks like the GM Two Mode Hybrids used a TRW designed Electro-Hydraulic Control Unit to control the regenerative braking system. Looking at AC Delco part 84078739 right now (dark and cold outside so cannot do anything except research until tomorrow). Hoping that maybe someone here has run into this issue before. The braking system appears to be highly sophisticated. I guess that I will try to find all the brake system components and check the electrical connections before doing anything else.
dnt1010
dnt1010
Tennessee
All Good now, the ABS codes are very accurate. Had water intrusion into the ABS control module which shorted the solenoids just as the code stated. Junkyard part and rolling again. Still have the hard turn stabiltrac blinking light though LOL
Capybarbro
