Name this OEM Strut
Christoph
Can someone help me find this front strut? It's OEM ACDELCO on a 2015 Yukon SLT 4x4 Tow Package Z85 suspension. Build date was October 2010.
The suspension on the build sheet is 6RW & 7RW. These codes don't match any on RockAuto.com unless I go to a 2014 model.
I'd like to go back with OEM if I could find this strut.
Any ideas?
Thanks in advance for any help.
Any ideas?
Your PN# is 23183877
ACDELCO = 540-1666
Double check here with your VIN:
https://parts-catalog.acdelco.com/catalog/catalog_search.php
Christoph
Christoph
ACDELCO = 540-1666
I checked with the VIN and the strut doesn't show as an option for 2015. I've spent hours trying to figure this out. The front Suspension rpo codes are 6RW & 7RW and they do not appear under the VIN or 2015 Yukon options. This is giving me a headache. I can show you the build sheet if that would help.
The ACDelco part number above coincides for the 6RW and 7RW RPO codes, it was 4 pages back on the ACDelco website, after the orange Rancho shocks.
You can give @915_Tahoe your VIN and he can look it up at work for you too but that's the current part number for those RPO codes.
Christoph
Christoph
Thanks much. I am giving this a shot now!
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
whats the last 8 of your vin#.
part# 23183877 is not an active number. but by vin# i can pull up the currant part#.
915_Tahoe
HELL PASO, TX
This is by vin#
front lh/rh absorber
GM#23179308 RPO CODE ZRW
IF NEEDING REAR. USE PART NO 23156090 RPO CODE Z85. ALSO THIS ABSORBER IS USED ON BOTH LEFT AND RIGHT SIDES.
Christoph
Christoph
Haha the
Any ideas?
Haha The build date was 10/2014...not 2010.
abruck
